Unofficial File parts/4614385f.dat
Sticker  2.6 x  2.8 with Black Trident, Gold Triangle and Symbols
0 Sticker 2.6 x 2.8 with Black Trident, Gold Triangle and Symbols 0 Name: 4614385f.dat 0 Author: Evert-Jan Boer [ejboer] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS ancient, BrickLink 7985stk01, Brickowl 816737, City of Atlantis 0 !KEYWORDS Rebrickable 94346, Set 7985, Temple, Underwater
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\stickerback026x028a.dat 1 16 0 -.25 0 1 0 0 0 1 0 0 0 1 s\4614385fs01.dat 1 16 0 -.25 0 -1 0 0 0 1 0 0 0 1 s\4614385fs01.dat 4 15 -.75 -.25 -21.75 -17.4481 -.25 -26.4871 17.4481 -.25 -26.4871 .75 -.25 -21.75 4 15 -26.5 -.25 26.4871 -10.5196 -.25 21.3062 10.5196 -.25 21.3062 26.5 -.25 26.4871 3 15 10.5196 -.25 21.3062 -10.5196 -.25 21.3062 0 -.25 20.7 4 0 .75 -.25 13.95 .4758 -.25 18.7808 -.4758 -.25 18.7808 -.75 -.25 13.95 3 0 0 -.25 20.7 -.4758 -.25 18.7808 .4758 -.25 18.7808 4 0 .75 -.25 4.2 .75 -.25 13.95 -.75 -.25 13.95 -.75 -.25 4.2 4 0 .75 -.25 1.55 .75 -.25 2.15 -.75 -.25 2.15 -.75 -.25 1.55 4 0 .75 -.25 -.05 .75 -.25 1.55 -.75 -.25 1.55 -.75 -.25 -.05 4 0 .75 -.25 -1.05 .75 -.25 -.05 -.75 -.25 -.05 -.75 -.25 -1.05 4 0 .75 -.25 -2.65 .75 -.25 -1.05 -.75 -.25 -1.05 -.75 -.25 -2.65 4 0 .75 -.25 -4.5 .75 -.25 -2.65 -.75 -.25 -2.65 -.75 -.25 -4.5 4 0 .75 -.25 -6.8 .75 -.25 -4.5 -.75 -.25 -4.5 -.75 -.25 -6.8 4 0 .75 -.25 -21.75 .75 -.25 -6.8 -.75 -.25 -6.8 -.75 -.25 -21.75 4 0 -.75 -.25 4.2 -.75 -.25 2.15 .75 -.25 2.15 .75 -.25 4.2
  • decimal places exceeds the recommendation for in the library specification
None
Part Reviewer
2024-10-05 18:24:56
Part Reviewer
posted a vote of Hold.
2025-08-18 20:18:19
BFC error on all four corners (primitves on top).
made the following comment.
2025-10-20 00:27:39
Should this use a sticker back file? It is common for this part to get the front surface fully covered.
Pattern looks fine thus far.
edited the part header.
2025-10-20 00:27:58
Header Edits
help:
0 !HELP
to
0 !HELP
keywords:
City of Atlantis, Set 7985
to
City of Atlantis, Set 7985, Temple, Ancient, Underwater
Part Reviewer
2025-12-17 17:15:02
corrected bfc errors, added stickerback (hope i got dimensions correct)
Part Reviewer
2025-12-17 17:51:07
changed for existing stickerback
Part Reviewer
2025-12-17 18:05:58
Just a comment (and a bit pedantic) but the two symbols at the bottom are not symmetrically placed with respect to the trident. Is the pattern complex enough to make use of mirroring?
Part Reviewer
2025-12-17 18:27:05
I was thinking about subfiling part of the pattern, did these stickers a long time ago, room for improvement
Rene Rechthaler [Blechtaler]
2025-12-17 18:31:23
now the sticker name size doesnt match the stickerback anymore, which is correct?
Part Reviewer
2025-12-17 18:35:45
Adjusted name and subfiled pattern
LDraw.org Parts Tracker,
