Unofficial File parts/7904.dat
View on Rebrickable
0 Plate 2 x 2 with Corner Round
0 Name: 7904.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\7904s01.dat
1 16 0 0 0 0 0 -1 0 1 0 -1 0 0 s\7904s01.dat
1 16 0 4 0 1 0 0 0 -1 0 0 0 1 stud4.dat
1 16 10 0 10 0 0 1 0 1 0 -1 0 0 stud.dat
1 16 -10 0 10 0 0 1 0 1 0 -1 0 0 stud.dat
1 16 -10 0 -10 0 0 1 0 1 0 -1 0 0 stud.dat
1 16 0 6 0 0 -16 0 2 0 0 0 0 16 box2-5.dat
1 16 0 4 0 0 -20 0 4 0 0 0 0 20 box2-5.dat
5 24 8.28 0 -8.28 8.28 4 -8.28 4.349696 0 -11.73182 11.73182 0 -4.349696
Needs 2 More Votes (N)
Has uncertified subfiles
- Decimal precision exceeds normal specification for part type
None
Not sure about the underside...
2025-12-29 10:42:11
yes, the underside 1-4 aring should be avoided as its bleeding through the front...
suggestion: use 1-12cylo for the sides with chrd on top/bottom and same for the 1-24 (cyli-Cylo and chrd), then fill the rest with quads
for the bottom 1-8 cutouts for the studs: also use cylo+chrd+tndis?
Thanks for the tips, and now subfiled
2025-12-29 14:22:03
2025-12-29 15:25:49
I guess I should add extra conds for the 1-48cylo
This part is copyright © Vincent Messenet
LDraw.org Parts Tracker,
