0 ~Sticker Back 2.0 x 3.8 - Flattened 6191b01
0 Name: s\stickerback020x038a.dat
0 !HELP Dimensions: 1.97812 x 3.8
0 // Primitives
1 16 -36.5 0 18.2812 -1.5 0 0 0 -1 0 0 0 1.5 1-4chrd.dat
1 16 36.5 0 18.2812 1.5 0 0 0 -1 0 0 0 1.5 1-4chrd.dat
1 16 0 -.25 0 0 0 38 0 .25 0 18.2812 0 0 box3u12.dat
1 16 -36.5 0 -18.2812 -1.5 0 0 0 -1 0 0 0 -1.5 1-4chrd.dat
1 16 36.5 0 -18.2812 1.5 0 0 0 -1 0 0 0 -1.5 1-4chrd.dat
1 16 -36.5 -0.25 18.2812 -1.5 0 0 0 0.25 0 0 0 1.5 1-4cyli.dat
1 16 36.5 -0.25 18.2812 1.5 0 0 0 0.25 0 0 0 1.5 1-4cyli.dat
1 16 -36.5 -0.25 -18.2812 -1.5 0 0 0 0.25 0 0 0 -1.5 1-4cyli.dat
1 16 36.5 -0.25 -18.2812 1.5 0 0 0 0.25 0 0 0 -1.5 1-4cyli.dat
0 // Bottom face
4 16 38 0 18.2812 -38 0 18.2812 -36.5 0 19.7812 36.5 0 19.7812
4 16 38 0 -18.2812 36.5 0 -19.7812 -36.5 0 -19.7812 -38 0 -18.2812
0 // Lateral face
4 16 -36.5 0 19.7812 -36.5 -.25 19.7812 36.5 -.25 19.7812 36.5 0 19.7812
4 16 -36.5 0 -19.7812 36.5 0 -19.7812 36.5 -.25 -19.7812 -36.5 -.25 -19.7812
- Decimal precision exceeds normal specification for part type
| User | Vote |
| OrionP | Hold |
| MagFors | Hold |
If you want to use a 2.0 x 1.8 flat part stickerback, you need to create a different one.
See the stickerback for 11477 part s\stickerback008x019.dat.
My solution: use a real Sticker Back 2.0 x 3.8, and slightly modify 6221655f.dat to fit:
1 16 0 0 -14.1961 -1 0 0 0 1 0 0 0 -1 s\6221655fs01.dat
1 16 0 0 -14.0967 -1 0 0 0 1 0 0 0 -1 s\6221655fs02.dat
1 16 0 0 2.0475 -1 0 0 0 1 0 0 0 -1 s\6221655fs03.dat
1 16 0 0 2.1469 -1 0 0 0 1 0 0 0 -1 s\6221655fs04.dat
1 16 0 0 10 -1 0 0 0 1 0 0 0 -1 s\6221655fs05.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\stickerback020x038.dat
4 0 -38 -.25 -5.8058 -38 -.25 -6.2434 38 -.25 -6.2434 38 -.25 -5.8058
help:
to
description:
to
Moved, extended description, added !HELP to specify exact dimensions.
The rule about 0.2 ldu around the edge is, IMHO only valid for the flat versions.
The flat version of the formed sticker, and the formed sticker, should be adapted.
A sticker 20 x 38 should be applied to a 44 x 80 part, which is a rather strange size to reuse so many times. The measurements of the parts will most easily be 40 x 80, stickerback018x038, or 48 x 80, stickerback022x038.
I understood that the stickerbacks are born to have the same sizes for the same use, not to have all the similar stickers of the same size whatever their use.
The idea of having two different stickerback020x038 is to allow the flat to have with his own measurements and the one flattened to have others, separating the two uses.
The difference is minimal and I will fix it, but in my opinion we are not respecting the spirit with which they were conceived and explained.
LDraw.org Parts Tracker,
