Unofficial File parts/7212p00.dat
Base Part: 7212.dat
0 Tile 6 x 6 Round with Super Mario Logo Red Capital Letter "M" Pattern
0 Name: 7212p00.dat
0 !KEYWORDS Bricklink 7212pb001, Mario Kart - Mario & Standard Kart
0 !KEYWORDS Rebrickable 7212pr0001, Sculptures, Set 72037, Super Mario
0 // Pattern-Basepart
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\7212s01.dat
0 // Pattern
4 4 -23 0 40 -50.5 0 -14.5 -33.5 0 -28 -18 0 14.5
4 4 0 0 17.5 -23 0 40 -18 0 14.5 0 0 -6.5
4 4 0 0 17.5 0 0 -6.5 18 0 14.5 23 0 40
4 4 50.5 0 -14.5 23 0 40 18 0 14.5 33.5 0 -28
1 16 0 0 0 60 0 0 0 1 0 0 0 60 1-8chrd.dat
1 16 0 0 0 42.42641 0 -42.42641 0 1 0 42.42641 0 42.42641 1-8chrd.dat
1 16 0 0 0 0 0 -60 0 1 0 60 0 0 1-8chrd.dat
1 16 0 0 0 -42.42641 0 -42.42641 0 1 0 42.42641 0 -42.42641 1-8chrd.dat
1 16 0 0 0 -60 0 0 0 1 0 0 0 -60 1-8chrd.dat
1 16 0 0 0 -42.42641 0 42.42641 0 1 0 -42.42641 0 -42.42641 1-8chrd.dat
1 16 0 0 0 0 0 60 0 1 0 -60 0 0 1-8chrd.dat
1 16 0 0 0 42.42641 0 42.42641 0 1 0 -42.42641 0 42.42641 1-8chrd.dat
1 16 0 0 0 60 0 0 0 1 0 0 0 60 48\4-4aring.dat
4 16 -23 0 40 0 0 17.5 23 0 40 0 0 59.999
3 16 -18 0 14.5 -33.5 0 -28 0 0 -6.5
4 16 33.5 0 -28 0 0 -6.5 -33.5 0 -28 0 0 -59.999
3 16 18 0 14.5 0 0 -6.5 33.5 0 -28
3 16 0 0 59.999 23 0 40 42.426 0 42.426
4 16 42.426 0 42.426 23 0 40 50.5 0 -14.5 60 0 0
3 16 0 0 59.999 -42.426 0 42.426 -23 0 40
4 16 -50.5 0 -14.5 -23 0 40 -42.426 0 42.426 -59.999 0 0
4 16 33.5 0 -28 0 0 -59.999 42.426 0 -42.426 50.5 0 -14.5
3 16 60 0 0 50.5 0 -14.5 42.426 0 -42.426
4 16 -42.426 0 -42.426 0 0 -59.999 -33.5 0 -28 -50.5 0 -14.5
3 16 -59.999 0 0 -42.426 0 -42.426 -50.5 0 -14.5
Errors Found (HHN)
- decimal places exceeds the recommendation for in the library specification
| User | Vote |
| GeraldLasser | Hold |
| Blechtaler | Hold |
2025-06-13 10:00:35
2025-06-13 10:03:50
the top shouldnt be hard coded white
Dump error. Corrected.
please use any round prims for the rim, the subfile has a cyli+edge...
either aring, chrd or what fits.
guess the pattern isnt complex enough to make a half subfile.
2025-06-14 18:02:19
2025-06-15 22:25:15
Instead of those:
1 13 0 0 0 42.42641 0 -42.42641 0 1 0 42.42641 0 42.42641 1-8chrd.dat
1 13 0 0 0 -42.42641 0 -42.42641 0 1 0 42.42641 0 -42.42641 1-8chrd.dat
1 13 0 0 0 -42.42641 0 42.42641 0 1 0 -42.42641 0 -42.42641 1-8chrd.dat
1 13 0 0 0 42.42641 0 42.42641 0 1 0 -42.42641 0 42.42641 1-8chrd.dat
use unrotated prims
1 14 0 0 0 60 0 0 0 1 0 0 0 -60 1-8chrd.dat
1 14 0 0 0 0 0 -60 0 1 0 -60 0 0 1-8chrd.dat
1 14 0 0 0 -60 0 0 0 1 0 0 0 60 1-8chrd.dat
1 14 0 0 0 0 0 60 0 1 0 60 0 0 1-8chrd.dat
THis will avoid those 59.999 vertices
you can then use either unificator to match those to the 60 or correct them by hand, i..e merge vertices
use unrotated prims
why do you even use both aring and chrd, one of them is enough...
its mainly for prim subst, and both meet that.
(just use either aring OR 48\1-8chrd.dat)
2025-06-16 05:17:08
I would tend to the aring and replace the chrds with triangles, then merge them to the neighboring ones...
Maybe split some quads to merge them better.
@rene, the aring is not subject to prim substitution, therefore the use of the 48/1-8chrds is ok, those are being substituted to the higher resolutions
I am putting the hold now becaus of my previous comment
This part is copyright © Gabriel Läufer
LDraw.org Parts Tracker,
