Unofficial File parts/169675i.dat
0 Sticker 1.1 x 1.9 with 4 Danger Stripes Chevron
0 Name: 169675i.dat
0 !KEYWORDS 9V Trains, Bricklink 4555stk01, Brickowl 985413, Cargo Station
0 !KEYWORDS Portal Crane, Rebrickable 169675, Set 4555
0 // Sticker Base
1 16 0 -.25 0 19 0 0 0 .25 0 0 0 11 box5-12.dat
0 // Pattern
4 0 -13.075 -.25 11 -18.025 -.25 11 0 -.25 -7.025 0 -.25 -2.075
4 0 18.025 -.25 11 13.075 -.25 11 0 -.25 -2.075 0 -.25 -7.025
4 0 -8.126 -.25 11 0 -.25 2.874 0 -.25 7.824 -3.176 -.25 11
4 0 8.126 -.25 11 3.176 -.25 11 0 -.25 7.824 0 -.25 2.874
4 0 -19 -.25 -2.874 -19 -.25 -7.824 -15.824 -.25 -11 -10.874 -.25 -11
4 0 -.975 -.25 -11 -19 -.25 7.025 -19 -.25 2.075 -5.925 -.25 -11
4 0 19 -.25 7.025 .975 -.25 -11 5.925 -.25 -11 19 -.25 2.075
4 0 15.824 -.25 -11 19 -.25 -7.824 19 -.25 -2.874 10.874 -.25 -11
3 14 18.025 -.25 11 19 -.25 7.025 19 -.25 11
3 14 -3.176 -.25 11 0 -.25 7.824 3.176 -.25 11
3 14 -19 -.25 -11 -15.824 -.25 -11 -19 -.25 -7.824
3 14 15.824 -.25 -11 19 -.25 -11 19 -.25 -7.824
3 14 -18.025 -.25 11 -19 -.25 11 -19 -.25 7.025
4 14 -.975 -.25 -11 0 -.25 -7.025 -18.025 -.25 11 -19 -.25 7.025
3 14 -.975 -.25 -11 .975 -.25 -11 0 -.25 -7.025
4 14 0 -.25 -7.025 .975 -.25 -11 19 -.25 7.025 18.025 -.25 11
4 14 -8.126 -.25 11 -13.075 -.25 11 0 -.25 -2.075 0 -.25 2.874
4 14 0 -.25 2.874 0 -.25 -2.075 13.075 -.25 11 8.126 -.25 11
4 14 -5.925 -.25 -11 -19 -.25 2.075 -19 -.25 -2.874 -10.874 -.25 -11
4 14 5.925 -.25 -11 10.874 -.25 -11 19 -.25 -2.874 19 -.25 2.075
Needs 2 More Votes (N)
None
2025-06-03 15:43:51
I think all 3 stickers are wrong:
004113b.dat (starts with a yellow center and ends with black corners, paper sticker)
820673l.dat (starts with a black center and ends with yellow corners, transparent sticker)
169675i.dat (alias of 820673l.dat, the cut lines arent visible on the BL pic like on the 820673)
2025-06-03 18:05:00
Seems you're right, 820673l and 169675i should be identical...
I'll take a look what else is related. There's also a printed version out there (30180pb03).
Would it be worth to split apart in half (and both colours) and use as subfiles if possible?
Does it matter in this case that the stickers are applied with a different orientation? In 6541 it points upwards, in 4555 downwards.
2025-06-03 18:40:20
no, just rotate the sticker when applying in the shortcut...
I dont think we need to subfile it for a that simple pattern.
This part is copyright © Chris Böhnke
LDraw.org Parts Tracker,
*there are similar stickers around with different stripe counts; currently the number of black ones is listed in the name
*actually this is printed on transparent foil, but covered all over in print and applied to an opaque part - NOCLIP required?
