Unofficial File parts/3808.dat
0 Duplo Plate 2 x 4 x 0.333 Half Circle with 2 Studs
0 Name: 3808.dat
0 Author: Chris Dee [cwdee]
0 !CATEGORY Plate
0 !HISTORY 2020-05-25 [PTadmin] Update description
0 !HISTORY 2025-04-30 [WUIt] CCW'd BFC, used more prims, removed microgaps
0 // top
1 16 20 0 0 1 0 0 0 2.75 0 0 0 1 stud7.dat
1 16 -20 0 0 1 0 0 0 2.75 0 0 0 1 stud7.dat
1 16 0 0 -20 80 0 0 0 1 0 0 0 80 48\2-4chrd.dat
0 // sides
1 16 0 0 -20 80 0 0 0 16 0 0 0 80 48\2-4cylo.dat
1 16 0 8 -20 -80 0 0 0 0 8 0 1 0 rect.dat
0 // bottom
1 16 0 4 20 1 0 0 0 -1.75 0 0 0 1 stug8-1x3.dat
1 16 0 16 -20 4 0 0 0 -1 0 0 0 4 48\2-4ring19.dat
4 16 -75.7364 16 -16 75.7364 16 -16 76 16 -20 -76 16 -20
2 24 75.7364 4 -16 75.3464 4 -10.082
2 24 75.7364 16 -16 75.3464 16 -10.082
4 16 75.3464 4 -10.082 75.3464 16 -10.082 75.7364 16 -16 75.7364 4 -16
2 24 -75.7364 4 -16 -75.3464 4 -10.082
2 24 -75.7364 16 -16 -75.3464 16 -10.082
4 16 -75.3464 16 -10.082 -75.3464 4 -10.082 -75.7364 4 -16 -75.7364 16 -16
1 16 0 10 -16 75.7364 0 0 0 0 6 0 -1 0 rect.dat
1 16 0 4 -20 0 0 76 0 12 0 76 0 0 48\11-48cylo.dat
1 16 0 4 -20 0 0 -76 0 12 0 76 0 0 48\11-48cylo.dat
1 16 0 4 -20 0 0 76 0 -1 0 76 0 0 48\11-48chrd.dat
1 16 0 4 -20 0 0 -76 0 -1 0 76 0 0 48\11-48chrd.dat
4 16 75.3464 4 -10.082 75.7364 4 -16 -75.7364 4 -16 -75.3464 4 -10.082
3 16 -75.3464 4 -10.082 0 4 56 75.3464 4 -10.082
1 16 60 9.5 -16 1.5 0 0 0 0 5.5 0 4 0 box4-1.dat
1 16 20 9.5 -16 1.5 0 0 0 0 5.5 0 4 0 box4-1.dat
1 16 -20 9.5 -16 1.5 0 0 0 0 5.5 0 4 0 box4-1.dat
1 16 -60 9.5 -16 1.5 0 0 0 0 5.5 0 4 0 box4-1.dat
1 16 20 9.5 56 1.5 0 0 0 0 5.5 0 -4 0 box4-1.dat
1 16 76 9.5 0 0 -4 0 0 0 5.5 -1.5 0 0 box4-1.dat
2 24 73.4084 15 -.3312 72.7877 15 1.5
2 24 73.6407 15 -1.5 73.4084 15 -.3312
2 24 72.7877 4 1.5 72.7877 15 1.5
2 24 73.6407 15 -1.5 73.6407 4 -1.5
2 24 18.5 15 53.6407 19.6688 15 53.4084
2 24 19.6688 15 53.4084 21.5 15 52.7877
2 24 18.5 15 53.6407 18.5 4 53.6407
2 24 21.5 15 52.7877 21.5 4 52.7877
1 16 -20 9.5 56 -1.5 0 0 0 0 5.5 0 -4 0 box4-1.dat
1 16 -76 9.5 0 0 4 0 0 0 5.5 -1.5 0 0 box4-1.dat
2 24 -72.7877 15 1.5 -73.4084 15 -.3312
2 24 -73.4084 15 -.3312 -73.6407 15 -1.5
2 24 -72.7877 15 1.5 -72.7877 4 1.5
2 24 -73.6407 4 -1.5 -73.6407 15 -1.5
2 24 -19.6688 15 53.4084 -18.5 15 53.6407
2 24 -21.5 15 52.7877 -19.6688 15 53.4084
2 24 -18.5 4 53.6407 -18.5 15 53.6407
2 24 -21.5 4 52.7877 -21.5 15 52.7877
Needs 2 More Votes (F)
- Decimal precision exceeds normal specification for part type
None
Made BFC compliant
2025-04-30 10:59:55
should the inside get changed to unrotated 11-48 prims? instead of the rotated 11-24
2025-04-30 15:29:20
A minor detail, don't know of the imprortance. This fils was already "BFC compliant", but you change it from CW to CCW.
Maybe the history should be corrected?
Increased the use of primitives as suggested.
Corrected history line as suggested.
There are four fillets missing along the semi circle, those allow for more connection variants
1 9 20 9.5 56 1.5 0 0 0 0 5.5 0 -4 0 box4-1.dat
1 9 -20 9.5 56 1.5 0 0 0 0 5.5 0 -4 0 box4-1.dat
1 9 -76 3.5 0 0 4 0 0 0 5.5 -1.5 0 0 box4-1.dat
1 9 76 3.5 0 0 -4 0 0 0 5.5 -1.5 0 0 box4-1.dat
Added the four missing fillets as suggested.
This part is copyright © Chris Dee
LDraw.org Parts Tracker,
Orion Pobursky,
Peter Blomberg,
