0 Minifig Hips with Magenta Flowers on Lime Shorts Pattern
0 Name: 3815bpx5.dat
0 Author: Jeff Jones [notmaster]
0 !KEYWORDS Bricklink 970c90pb02, Patrick Star, set 3816, Set 3818, Set 3827
0 !KEYWORDS Set 3830, Set 3832, Set 4982, Set Set 3833, SpongeBob SquarePants
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3815bs01.dat
1 16 -2 12 0 0 4 0 8.08395 0 -3.34848 -3.34848 0 -8.08395 5-16cyli.dat
3 16 -17 .75 -10 -12.53 .75 -10 -18 0 -10
3 16 17 5.25 -10 13.43 5.25 -10 18 6 -10
3 16 -17 5.25 -10 -18 6 -10 -12.07 5.25 -10
4 16 18 6 -10 13.43 5.25 -10 -12.07 5.25 -10 -18 6 -10
4 16 -18 6 -10 -17 5.25 -10 -17 .75 -10 -18 0 -10
4 16 18 0 -10 17 .75 -10 17 5.25 -10 18 6 -10
4 27 -17 5.25 -10 -12.55 3.47 -10 -12.53 .75 -10 -17 .75 -10
3 27 12.53 .75 -10 12.85 1.23 -10 17 .75 -10
3 27 12.85 1.23 -10 13.06 1.61 -10 17 .75 -10
3 27 13.06 1.61 -10 13.24 2.04 -10 17 .75 -10
4 27 13.24 2.04 -10 13.39 2.84 -10 17 5.25 -10 17 .75 -10
3 27 17 5.25 -10 13.39 2.84 -10 13.43 5.25 -10
3 27 -12.55 3.47 -10 -17 5.25 -10 -12.47 4.26 -10
3 27 -12.47 4.26 -10 -17 5.25 -10 -12.36 4.74 -10
3 27 -12.36 4.74 -10 -17 5.25 -10 -12.07 5.25 -10
4 26 12.53 .75 -10 -12.53 .75 -10 -12.55 3.47 -10 12.85 1.23 -10
4 26 13.06 1.61 -10 12.85 1.23 -10 -12.55 3.47 -10 -12.47 4.26 -10
4 26 13.24 2.04 -10 13.06 1.61 -10 -12.47 4.26 -10 -12.36 4.74 -10
4 26 13.39 2.84 -10 13.24 2.04 -10 -12.36 4.74 -10 -12.07 5.25 -10
3 26 13.43 5.25 -10 13.39 2.84 -10 -12.07 5.25 -10
4 16 -12.53 .75 -10 12.53 .75 -10 18 0 -10 -18 0 -10
3 16 17 .75 -10 18 0 -10 12.53 .75 -10
- Ensure correct Minifig category
- Decimal precision exceeds normal specification for part type
| User | Vote |
| KnightOfTarenta | Hold |
- Line separation between lime ends and middle should be straight vertical
- I see no flowers here?! description should be updated.
- do we have evidence that 2 different versions are available??? I can see only one.
- IMHO, not worth subparting (even less if there is only one version!)
before i inline the subparts should it be bright reddish lilac flowers or magenta flowers?
4644875 the newer Magenta one.
https://www.flickr.com/photos/126975831@N07/15129029306/in/dateposted/
Not sure if you consider the Lego.com sourced inventories from Brickset reliable:
https://brickset.com/inventories/3827-1
https://brickset.com/sets/3818-1/Bikini-Bottom-Undersea-Party
They list the legs with a different Element ID (though still with the same Print No. 108). According the FlickR group, only the post 2011 sets seems to contain the Magenta one.
"how many ldu should the print be?"
Something like 4.5ldu tall, 34ldu wide
full assembly coming soon.
description:
Minifig Hips with Magenta on Lime Shorts Pattern
to
Either use sub-files on both or on none.
This part is copyright © Jeff Jones
LDraw.org Parts Tracker,
