0 ~Duplo Plate 1 x 2 with Overhang - Half
0 Name: s\42236s02.dat
0 !HISTORY 2024-12-21 [WUIt] Added missing sides, corrected z-dimension of large reinforcement, removed T-junctions, subfiled for symmetry
4 16 36 10 -53 36 10 -45 40 10 -45 40 10 -56
2 24 36 10 -45 36 10 -53
2 24 36 24 16 36 24 -20
2 24 40 10 -45 36 10 -45
4 16 36 24 16 36 24 -20 36 4 -41 36 4 16
4 16 36 24 16 40 24 20 40 24 -20 36 24 -20
1 16 20 4 14 1.5 0 0 0 19 0 0 0 -2 box4-1.dat
1 16 34 4 0 0 0 -2 0 19 0 1.5 0 0 box4-1.dat
2 24 12.5 19 -10 9.5 19 -10
2 24 9.5 19 -10 9.5 19 -14
2 24 12.5 19 -12 12.5 19 -10
2 24 12.5 4 -10 9.5 4 -10
2 24 9.5 4 -10 9.5 4 -14
2 24 12.5 4 -12 12.5 4 -10
2 24 12.5 4 -10 12.5 19 -10
2 24 9.5 4 -10 9.5 19 -10
2 24 9.5 4 -14 9.5 19 -14
4 16 12.5 19 -12 9.5 19 -14 9.5 19 -10 12.5 19 -10
4 16 12.5 4 -10 12.5 19 -10 9.5 19 -10 9.5 4 -10
4 16 9.5 4 -10 9.5 19 -10 9.5 19 -14 9.5 4 -14
4 16 12.5 4 -12 12.5 19 -12 12.5 19 -10 12.5 4 -10
1 16 11 4 13 1.5 0 0 0 15 0 0 0 -3 box4-1.dat
2 24 40 24 20 40 24 -20
2 24 40 10 -45 40 10 -56
2 24 40 10 -45 40 45 -45
1 16 36 10 -45 0 1 0 0 0 -8 -8 0 0 1-4disc.dat
1 16 40 10 -45 0 -1 0 -10 0 0 0 0 -11 1-4disc.dat
2 24 21.5 4 -41 21.5 68 -41
2 24 18.5 4 -41 18.5 68 -41
2 24 18.5 68 -41 21.5 68 -41
2 24 18.5 68 -36 21.5 68 -36
2 24 18.5 58 -20 21.5 58 -20
2 24 18.5 24 -20 21.5 24 -20
2 24 18.5 24 -12 21.5 24 -12
2 24 21.5 4 -12 21.5 24 -12
2 24 12.5 4 -12 12.5 19 -12
2 24 18.5 4 -14 18.5 19 -14
2 24 9.5 4 -14 18.5 4 -14
2 24 9.5 19 -14 18.5 19 -14
2 24 12.5 4 -12 21.5 4 -12
2 24 12.5 19 -12 18.5 19 -12
2 24 21.5 24 -20 21.5 24 -12
2 24 18.5 24 -20 18.5 24 -12
2 24 18.5 19 -14 18.5 19 -12
2 24 18.5 19 -12 18.5 24 -12
2 24 18.5 24 -20 18.5 58 -20
2 24 21.5 24 -20 21.5 58 -20
2 24 21.5 68 -36 21.5 58 -20
2 24 21.5 4 -41 21.5 4 -12
2 24 18.5 4 -41 18.5 4 -14
2 24 18.5 68 -36 18.5 58 -20
4 16 18.5 4 -41 18.5 58 -20 18.5 68 -36 18.5 68 -41
4 16 21.5 68 -36 21.5 68 -41 18.5 68 -41 18.5 68 -36
4 16 21.5 58 -20 21.5 68 -36 18.5 68 -36 18.5 58 -20
4 16 21.5 24 -12 21.5 24 -20 18.5 24 -20 18.5 24 -12
4 16 21.5 4 -12 21.5 24 -12 18.5 24 -12 18.5 19 -12
4 16 21.5 4 -12 18.5 19 -12 12.5 19 -12 12.5 4 -12
4 16 9.5 4 -14 9.5 19 -14 18.5 19 -14 18.5 4 -14
4 16 18.5 19 -12 18.5 19 -14 9.5 19 -14 12.5 19 -12
4 16 18.5 58 -20 18.5 24 -20 21.5 24 -20 21.5 58 -20
4 16 21.5 58 -20 21.5 4 -41 21.5 68 -41 21.5 68 -36
3 16 21.5 24 -20 21.5 4 -41 21.5 58 -20
3 16 18.5 24 -20 18.5 58 -20 18.5 4 -41
4 16 21.5 4 -12 21.5 4 -41 21.5 24 -20 21.5 24 -12
4 16 18.5 19 -14 18.5 19 -12 18.5 24 -12 18.5 24 -20
4 16 18.5 19 -14 18.5 24 -20 18.5 4 -41 18.5 4 -14
2 24 18.5 68 -36 18.5 68 -41
2 24 21.5 68 -36 21.5 68 -41
0 // side
2 24 40 45 -41 40 45 -33
2 24 36 45 -41 36 45 -33
2 24 36 45 -33 36 36 -33
2 24 36 45 -23 44 45 -23
2 24 36 45 -20 44 45 -20
2 24 44 45 -20 44 45 -23
2 24 36 45 -33 44 45 -33
4 16 40 24 20 40 0 20 40 20 -20 40 24 -20
4 16 40 10 -45 40 45 -45 40 45 -41 40 36 -36
1 16 40 36 -20 0 -1 0 -16 0 0 0 0 -16 1-4ndis.dat
1 16 40 36 -20 0 -1 0 0 0 16 -16 0 0 1-16tndis.dat
1 16 48 36 -20 0 -8 0 -16 0 0 0 0 -16 5-16cylo.dat
1 16 48 36 -20 0 -1 0 -16 0 0 0 0 -16 5-16chrd.dat
1 16 48 36 -20 0 -4 0 16 0 0 0 0 -16 1-8cylo.dat
1 16 48 36 -20 0 -1 0 16 0 0 0 0 -16 1-8chrd.dat
1 16 44 36 -20 0 1 0 16 0 0 0 0 -16 1-8chrd.dat
2 24 48 52 -20 48 20 -20
2 24 48 20 -20 40 20 -20
2 24 48 52 -20 44 52 -20
1 16 44 36 -23 0 -8 0 -12 0 0 0 0 -10 1-4cylo.dat
1 16 44 36 -23 0 1 0 -12 0 0 0 0 -10 1-4chrd.dat
1 16 36 36 -23 0 1 0 -12 0 0 0 0 -10 1-4ndis.dat
4 16 44 36 -33 44 45 -33 36 45 -33 36 36 -33
2 24 44 45 -33 44 36 -33
2 24 44 24 -23 44 45 -23
2 24 44 24 -23 36 24 -23
2 24 36 24 -23 36 45 -23
2 24 48 42.1232 -34.7824 48 45 -33
2 24 40 42.1232 -34.7824 40 45 -33
4 16 48 42.1232 -34.7824 40 42.1232 -34.7824 44 45 -33 48 45 -33
3 16 44 45 -33 40 42.1232 -34.7824 40 45 -33
2 24 48 47.3136 -31.3136 48 45 -33
2 24 44 47.3136 -31.3136 44 45 -33
4 16 44 45 -33 44 47.3136 -31.3136 48 47.3136 -31.3136 48 45 -33
4 16 40 10 -45 40 36 -36 40 20 -36 40 0 -45
4 16 40 20 -36 40 20 -20 40 0 20 40 0 -45
4 16 36 45 -20 36 24 -20 40 24 -20 44 45 -20
4 16 48 20 -20 44 45 -20 40 24 -20 40 20 -20
4 16 44 45 -20 48 20 -20 48 52 -20 44 52 -20
4 16 36 45 -23 44 45 -23 44 24 -23 36 24 -23
4 16 44 45 -20 44 45 -23 36 45 -23 36 45 -20
4 16 44 45 -33 44 36 -33 44 24 -23 44 45 -23
4 16 36 45 -33 40 45 -33 40 45 -41 36 45 -41
4 16 36 45 -23 36 24 -23 36 24 -20 36 45 -20
2 24 44 52 -20 44 45 -20
2 24 40 20 -20 40 24 -20
2 24 40 24 -20 36 24 -20
2 24 36 24 -20 36 45 -20
2 24 36 45 -23 36 45 -20
2 24 40 45 -41 36 45 -41
3 16 36 4 -41 36 24 -20 36 24 -23
3 16 36 4 -41 36 24 -23 36 24 -33
3 16 36 45 -33 36 45 -41 36 36 -33
4 16 36 24 -33 36 36 -33 36 45 -41 36 4 -41
4 16 48 45 -33 48 47.3136 -31.3136 48 52 -20 48 20 -20
3 16 48 45 -33 48 20 -20 48 42.1232 -34.7824
4 16 44 52 -20 44 47.3136 -31.3136 44 45 -33 44 45 -23
3 16 44 52 -20 44 45 -23 44 45 -20
4 16 40 45 -33 40 42.1232 -34.7824 40 42.1232 -36 40 45 -41
3 16 40 45 -41 40 42.1232 -36 40 36 -36
1 16 0 45 -41 40 0 0 0 0 40 0 -1 0 48\1-4chrd.dat
3 16 40 45 -41 0 85 -41 36 45 -41
5 24 44 45 -33 48 45 -33 44 47.3136 -31.3136 48 42.1232 -34.7824
5 24 40 42.1232 -34.7824 48 42.1232 -34.7824 44 45 -33 40 36 -36
5 24 44 47.3136 -31.3136 48 47.3136 -31.3136 44 45 -33 44 50.7824 -26.1232
- decimal places exceeds the recommendation for in the library specification
None
description:
~Duplo Plate 1 x 2 with Overhang (Half)
to
Changed parenthesis to dash in description
rear of the big bottom cylo should be a hi-res 1-4chrd (instead of disc)
and it's not on the line:
2 24 48 42.1232 -34.7824 41.98 46.93 -30.5
This means that the side would require not only an extra triangle, but a cond line too.
So this design actually saves one cond line.
(I think you should redo that intersection to have that one segment flat)
This part is copyright © Michael Heidemann
LDraw.org Parts Tracker,
Peter Blomberg,
