Unofficial File parts/43418p01-f2.dat
Part Attributes: Base Part: 43418-f1.dat
Minifig Torso with Yellow Arms with Integral Hand (Up Position) Pattern
0 Minifig Torso with Yellow Arms with Integral Hand (Up Position) Pattern 0 Name: 43418p01-f2.dat 0 Author: Jeff Jones [notmaster] 0 !LDRAW_ORG Unofficial_Shortcut 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 !HELP Up position arm angle: 75° 0 !HELP Ball position: y=5, z=-29 0 !HELP 1 16 0 5 -29 1 0 0 0 1 0 0 0 1 43702.dat 0 BFC CERTIFY CCW 0 !KEYWORDS basketball, Bricklink 973bc01, NBA, Rebrickable 973b01, Set 10121-1 0 !HISTORY 2024-10-25 [notmaster] modified from 43370c01-f2.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 43370.dat 1 14 -15.552 9 0 0.985 -0.044 -0.16428 0.17 0.25494 0.95185 0 -0.9655 0.25882 43368.dat 1 14 15.552 9 0 0.985 0.044 0.16428 -0.17 0.25494 0.95185 0 -0.9655 0.25882 43369.dat
  • Ensure correct Minifig category
  • decimal places exceeds the recommendation for in the library specification
None
Part Author
2024-10-25 10:20:34
don't know if part number is correct
Orion Pobursky [OrionP]
made the following comment.
2024-10-25 12:17:29
If you're not sure of the number, per policy don't upload, ask.
Part Author
2024-10-25 12:29:01
ok
renamed the part.
2025-07-13 06:11:30
"parts/43370x01-f2.dat" to "parts/43370p01-f2.dat"
renamed the part.
2025-07-13 06:18:07
"parts/43370p01-f2.dat" to "parts/43370c01p01-f2.dat"
renamed the part.
2025-07-16 14:20:21
"parts/43370c01p01-f2.dat" to "parts/43418p01-f2.dat"
edited the part header.
2025-07-16 14:26:20
Header Edits
description:
to
This part is copyright © Jeff Jones
LDraw.org Parts Tracker,
