Unofficial File parts/3005d08.dat
Base Part: 3005.dat
0 Brick 1 x 1 with White Rectangle Sticker
0 Name: 3005d08.dat
0 !CATEGORY Sticker Shortcut
0 !KEYWORDS Batmobile (1989), Bricklink 3005pb050, Set 76139
0 !KEYWORDS Tim Burton's Batman
0 // Sticker-Base
1 16 0 0 0 1 0 0 0 1 0 0 0 1 3005.dat
0 // Sticker
1 16 0 12 -10 1 0 0 0 0 -1 0 1 0 6280006m.dat
Errors Found (CCHN)
| User | Vote |
| OrionP | Hold |
| GeraldLasser | Certify |
| RainbowDolphin | Certify |
2024-10-20 21:12:39
2024-10-20 23:32:00
"parts/3005d10.dat" to "parts/3005d08.dat"
This is a very odd usage.
The backside of this sticker is the "pattern" that create a white surface, viewed through the trans yellow brick.
Does it need to be bfc noclip?
Or do we hard code it, to have a white backside, in this shortcut?
2024-10-26 08:58:04
For those who wants to have a closer look how the sticker is used: Instruction page 268 e.g. step 389 or speeedbuild at min 07:30 (https://www.youtube.com/watch?v=fM1Gw1UM6-4). I would tend to white backside.
2025-02-18 13:50:04
2025-02-18 14:32:17
"Does it need to be bfc noclip?
Or do we hard code it, to have a white backside, in this shortcut? "
I'd say both.
I'd say both.
2025-06-16 20:39:33
I would say hardcoding white is enough, doesnt look like a transparent sticker sheet...
2025-06-16 21:03:52
Definitely needs to be hardcoded white.
I checked with the Library's 3D viewer and no NOCLIP is fine. How does LDView behave without NOCLIP? If it's fine then no NOCLIP needed.
2025-06-16 21:26:46
I couldn't tell any difference here, if NOCLIP is used or not in LDView, but it still looks awkward in both cases if the back isn't white.
This part is copyright © Gabriel Läufer
LDraw.org Parts Tracker,
After d01-d09 comes d0a-d0z, not d10.
d08 is not used.
We should renumber this.
