Unofficial File parts/4622098cc01.dat
Part Attributes: Base Part: 4622098c.dat
Sticker  1.8 x  0.7 with White Surface (Formed)
0 Sticker 1.8 x 0.7 with White Surface (Formed) 0 Name: 4622098cc01.dat 0 Author: Gabriel Läufer [Dr.Bricktacular] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS Anakin's & Sebulba's Podracers, Bricklink 7962stk01, Brickowl 968771 0 !KEYWORDS Rebrickable 95687, Set 7962, Star Wars 0 !HISTORY 2025-06-10 [Dr.Bricktacular] Created based on 6221655fc01.dat by Massimo Maso [Sirio]
0 // Sticker-Base 0 // Primitives 1 16 -6.5 .6826 -13.4328 -1.5 0 0 0 -.980797 -.292548 0 -.195032 1.471195 1-4chrd.dat 1 16 6.5 .6826 -13.4328 1.5 0 0 0 -.980797 -.292548 0 -.195032 1.471195 1-4chrd.dat 1 16 -6.5 .6826 -13.4328 -1.5 0 0 0 -.245199 -.292548 0 -.048758 1.471195 1-4cyli.dat 1 16 6.5 .6826 -13.4328 1.5 0 0 0 -.245199 -.292548 0 -.048758 1.471195 1-4cyli.dat 1 16 -6.5 28.5 -30 -1.5 0 0 0 0 1.5 0 -1 0 1-4chrd.dat 1 16 6.5 28.5 -30 1.5 0 0 0 0 1.5 0 -1 0 1-4chrd.dat 1 16 -6.5 28.5 -30 -1.5 0 0 0 0 1.5 0 -.25 0 1-4cyli.dat 1 16 6.5 28.5 -30 1.5 0 0 0 0 1.5 0 -.25 0 1-4cyli.dat 0 // Bottom faces 4 16 -6.5 .3901 -11.9616 6.5 .3901 -11.9616 8 .6826 -13.432 -8 .6826 -13.432 4 16 -8 .6826 -13.432 8 .6826 -13.432 8 1.522 -17.654 -8 1.522 -17.654 4 16 -8 1.522 -17.654 8 1.522 -17.654 8 5.858 -24.142 -8 5.858 -24.142 4 16 -8 5.858 -24.142 8 5.858 -24.142 8 12.346 -28.478 -8 12.346 -28.478 4 16 -8 12.346 -28.478 8 12.346 -28.478 8 20 -30 -8 20 -30 4 16 -8 20 -30 8 20 -30 8 28.5 -30 -8 28.5 -30 4 16 -8 28.5 -30 8 28.5 -30 6.5 30 -30 -6.5 30 -30 0 // Conditional lines 5 24 -8 1.522 -17.654 8 1.522 -17.654 -6.5 .3901 -11.9616 -8 5.858 -24.142 5 24 -8 5.858 -24.142 8 5.858 -24.142 -8 1.522 -17.654 -8 12.346 -28.478 5 24 -8 12.346 -28.478 8 12.346 -28.478 -8 5.858 -24.142 -8 20 -30 5 24 -8 20 -30 8 20 -30 -8 12.346 -28.478 -6.5 30 -30 0 // Lateral faces 4 16 -6.5 .3901 -11.9616 -6.5 .1449 -12.0104 6.5 .1449 -12.0104 6.5 .3901 -11.9616 4 16 -8 .6826 -13.4328 -8 1.522 -17.654 -8 1.2865 -17.7516 -8 .4374 -13.4815 4 16 -8 1.522 -17.654 -8 5.858 -24.142 -8 5.6778 -24.3222 -8 1.2865 -17.7516 4 16 -8 5.858 -24.142 -8 12.346 -28.478 -8 12.2484 -28.7135 -8 5.6778 -24.3222 4 16 -8 12.346 -28.478 -8 20 -30 -8 19.9754 -30.25 -8 12.2484 -28.7135 4 16 -8 20 -30 -8 28.5 -30 -8 28.5 -30.25 -8 19.9754 -30.25 4 16 8 .6826 -13.4328 8 .4374 -13.4815 8 1.2865 -17.7516 8 1.522 -17.654 4 16 8 1.522 -17.654 8 1.2865 -17.7516 8 5.6778 -24.3222 8 5.858 -24.142 4 16 8 5.858 -24.142 8 5.6778 -24.3222 8 12.2484 -28.7135 8 12.346 -28.478 4 16 8 12.346 -28.478 8 12.2484 -28.7135 8 19.9754 -30.25 8 20 -30 4 16 8 20 -30 8 19.9754 -30.25 8 28.5 -30.25 8 28.5 -30 4 16 -6.5 30 -30 6.5 30 -30 6.5 30 -30.25 -6.5 30 -30.2 0 // Conditional lines 5 24 -8 1.2865 -17.7516 8 1.2865 -17.7516 -6.5 .1449 -12.0104 -8 5.6778 -24.3222 5 24 -8 5.6778 -24.3222 8 5.6778 -24.3222 -8 1.2865 -17.7516 -8 12.2484 -28.7135 5 24 -8 12.2484 -28.7135 8 12.2484 -28.7135 -8 5.6778 -24.3222 -8 19.9754 -30.25 5 24 -8 19.9754 -30.25 8 19.9754 -30.25 -8 12.2484 -28.7135 -6.5 30 -30.2 0 // Sticker-Front 1 15 -6.5 .437401 -13.481558 -1.5 0 0 0 .980797 -.292548 0 .195032 1.471195 1-4chrd.dat 1 15 6.5 .437401 -13.481558 1.5 0 0 0 .980797 -.292548 0 .195032 1.471195 1-4chrd.dat 1 15 -6.5 28.5 -30.25 -1.5 0 0 0 0 1.5 0 1 0 1-4chrd.dat 1 15 6.5 28.5 -30.25 1.5 0 0 0 0 1.5 0 1 0 1-4chrd.dat 4 15 -8 28.5 -30.25 -6.5 30 -30.25 6.5 30 -30.25 8 28.5 -30.25 4 15 8 19.9754 -30.25 -8 19.9754 -30.25 -8 28.5 -30.25 8 28.5 -30.25 4 15 8 12.2484 -28.7135 -8 12.2484 -28.7135 -8 19.9754 -30.25 8 19.9754 -30.25 4 15 8 5.6778 -24.3222 -8 5.6778 -24.3222 -8 12.2484 -28.7135 8 12.2484 -28.7135 4 15 8 1.2865 -17.7516 -8 1.2865 -17.7516 -8 5.6778 -24.3222 8 5.6778 -24.3222 4 15 8 .437401 -13.481558 -8 .437401 -13.481558 -8 1.2865 -17.7516 8 1.2865 -17.7516 4 15 6.5 .144853 -12.010363 -6.5 .144853 -12.010363 -8 .437401 -13.481558 8 .437401 -13.481558
  • decimal places exceeds the recommendation for in the library specification
None
Part Reviewer
2024-10-20 20:47:07
Jeff Jones [notmaster]
Part Author
made the following comment.
2024-10-20 20:49:08
every subpart of the sticker is missing
Orion Pobursky [OrionP]
posted a vote of Hold.
2024-10-20 21:00:07
As this sticker is all white, I question why subfiles are even needed.
Gerald Lasser [GeraldLasser]
2024-10-21 09:33:12
Subfiles not needed, no pattern on the sticker
Part Reviewer
2024-10-22 21:58:09
Understood. Will move all faces to the main file. Try to do it tomorrow.
Part Reviewer
2024-10-23 10:16:51
Subfiles moved to the main part file. Took me a while to find the correct position of the white primitives on top. Updated keywords to better match with 4622098b.dat. Hopefully better now.
This part is copyright © Gabriel Läufer
LDraw.org Parts Tracker,
