0 Sticker 1.8 x 1.8 Round with Black Atlantis Trident
0 Name: 4614385g.dat
0 !KEYWORDS BrickLink 7985stk01, Brickowl 816737, City of Atlantis
0 !KEYWORDS Rebrickable 94346, Set 7985
1 16 0 0 0 18 0 0 0 -0.25 0 0 0 18 4-4cylc3.dat
1 4 0 -.25 0 18 0 0 0 1 0 0 0 18 4-4ering.dat
1 0 0 -.25 0 1 0 0 0 1 0 0 0 1 logo-atlantis-trident.dat
1 4 0 -.25 0 1 0 0 0 1 0 0 0 1 logo-atlantis-trident-box.dat
4 4 0 -.25 18 -6.8886 -.25 16.6302 -7 -.25 11 7 -.25 11
4 4 6.8886 -.25 16.6302 0 -.25 18 7 -.25 11 12.7278 -.25 12.7278
4 4 16.6302 -.25 6.8886 12.7278 -.25 12.7278 7 -.25 11 18 -.25 0
4 4 18 -.25 0 7 -.25 11 7 -.25 -10.3 16.6302 -.25 -6.8886
4 4 12.7278 -.25 -12.7278 16.6302 -.25 -6.8886 7 -.25 -10.3 6.8886 -.25 -16.6302
4 4 6.8886 -.25 -16.6302 7 -.25 -10.3 1.4 -.25 -15.9 0 -.25 -18
4 4 0 -.25 -18 1.4 -.25 -15.9 -1.4 -.25 -15.9 -6.8886 -.25 -16.6302
4 4 -6.8886 -.25 -16.6302 -1.4 -.25 -15.9 -7 -.25 -10.3 -12.7278 -.25 -12.7278
4 4 -16.6302 -.25 -6.8886 -12.7278 -.25 -12.7278 -7 -.25 -10.3 -18 -.25 0
4 4 -18 -.25 0 -7 -.25 -10.3 -7 -.25 11 -16.6302 -.25 6.8886
4 4 -12.7278 -.25 12.7278 -16.6302 -.25 6.8886 -7 -.25 11 -6.8886 -.25 16.6302
Has uncertified subfiles
- decimal places exceeds the recommendation for in the library specification
None
maybe use a half subfile?
description:
Sticker 1.7 x 1.7 Round with Black Atlantis Trident
to
it could even use standard res in the subfile, the 6451155a.dat gets an additional aring...
*center tip of trident needs to be sharper
*why orient vertically? The real part has it at roughly 45 degree (needs to be measured likely)
*could be sub-filed to reuse for the color-inverted version in Set 8075
*I didn't check the entire Atlantis line, but it appears in multiple sets I'd say. Should the logo become a prim?
This orientation is per spec. IF the real part has it rotated then it should be rotated on the shortcut.
"Top is defined as either the logical top of a picture, text, etc. or, in the case of more abstract patterns, what the top is when the sticker is applied."
My argument would be:
While it could be argued that the "logical" orientation of the trident would be upright, it contradicts the "applied" form. And this shape is technically a logo, not a "full trident".
This might be a redundant discussion, but I think in terms of geometry and rounding errors, having the base orientation match the applied version will cause less issues.
Should this be discussed in the forums?
This pattern still has other issues though.
LDraw.org Parts Tracker,
1 16 0 0 0 18 0 0 0 -0.25 0 0 0 18 48\4-4cylc3.dat
should the title get corrected? (headeredit)
