Official File parts/16000pdg8.dat
Base Part: 16000.dat
View on BrickLink
0 Minifig Arm Right with Red Fire Vest, Metallic Spiked Cuff Pattern
0 Name: 16000pdg8.dat
0 !HELP Place at -15.552 9 0 relative to torso
0 !HELP Then rotate about x axis to give required elevation of arm
0 !HELP 0 = upper arm vertical
0 !HELP -45 = lower arm horizontal
0 !HELP -90 = upper arm horizontal
0 !HELP -135 = lower arm vertical
0 !HELP Then rotate 9.782 about z axis to align with slope of torso
0 !KEYWORDS animal, Bricklink 982pb299, CMF, set 71033, The Muppets
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\16000s03.dat
1 25 0 0 0 1 0 0 0 1 0 0 0 1 s\16000s04.dat
1 25 0 0 0 1 0 0 0 1 0 0 0 1 s\16000pdg8s01.dat
0 // Upper arm
4 4 -1.1352 -2.6135 -5.6928 0 -2.6658 -5.8862 0 -4.596 -4.596 -1.768 -4.066 -4.596
3 4 -1.1352 -2.6135 -5.6928 -1.768 -4.066 -4.596 -2.4996 -2.4856 -5.4741
4 4 -2.4996 -2.4856 -5.4741 -1.768 -4.066 -4.596 -4.024 -2.829 -4.596 -3.5716 -2.2859 -5.1851
3 4 -3.5716 -2.2859 -5.1851 -4.024 -2.829 -4.596 -3.9591 -2.075 -4.925
3 4 -3.9591 -2.075 -4.925 -4.024 -2.829 -4.596 -4.4838 -1.725 -4.596
4 4 -5.1768 -0.875 -3.925 -4.4838 -1.725 -4.596 -4.024 -2.829 -4.596 -4.746 -3.695 -2.487
3 4 -5.1768 -0.875 -3.925 -4.746 -3.695 -2.487 -5.8897 -0.025 -3.225
3 4 -4.746 -3.695 -2.487 -6.6226 0.825 -2.483 -5.8897 -0.025 -3.225
3 4 -4.024 -2.829 -4.596 -2.31 -5.312 -2.487 -4.746 -3.695 -2.487
3 4 -1.768 -4.066 -4.596 -2.31 -5.312 -2.487 -4.024 -2.829 -4.596
4 4 -2.31 -5.312 -2.487 -1.768 -4.066 -4.596 0 -4.596 -4.596 0 -6.005 -2.488
4 4 -2.31 -5.312 -2.487 0 -6.005 -2.488 0 -6.5 0 -2.5 -5.75 0
3 4 -2.31 -5.312 -2.487 -2.5 -5.75 0 -4.746 -3.695 -2.487
3 4 -4.746 -3.695 -2.487 -2.5 -5.75 0 -5 -4 0
4 4 -6.6226 0.825 -2.483 -4.746 -3.695 -2.487 -5 -4 0 -6.8868 1.275 -1.975
4 4 -7.111 1.65 -1.525 -6.8868 1.275 -1.975 -5 -4 0 -7.3608 2.05 -0.975
4 4 -7.5438 2.325 -0.525 -7.3608 2.05 -0.975 -5 -4 0 -7.7267 2.5723 0
4 4 -6.1724 -0.75 1.15 -6.5196 0.05 1.05 -7.7267 2.5723 0 -5 -4 0
3 4 -6.1724 -0.75 1.15 -5 -4 0 -5.8334 -1.475 1.4
3 4 -5.8334 -1.475 1.4 -5 -4 0 -5.5347 -2.075 1.725
3 4 -5.5347 -2.075 1.725 -5 -4 0 -5.2077 -2.725 2.1
4 4 -4.9106 -3.3 2.487 -5.2077 -2.725 2.1 -5 -4 0 -4.746 -3.695 2.487
3 4 -5 -4 0 -2.5 -5.75 0 -4.746 -3.695 2.487
3 4 -4.746 -3.695 2.487 -2.5 -5.75 0 -2.31 -5.312 2.487
4 4 -2.31 -5.312 2.487 -2.5 -5.75 0 0 -6.5 0 0 -6.005 2.488
4 4 -2.31 -5.312 2.487 0 -6.005 2.488 0 -4.596 4.596 -1.768 -4.066 4.596
3 4 -4.024 -2.829 4.596 -2.31 -5.312 2.487 -1.768 -4.066 4.596
4 4 -4.0839 -3.6 3.325 -4.026 -3.75 3.15 -2.31 -5.312 2.487 -4.024 -2.829 4.596
4 4 -7.6483 3.1 2 -7.7107 3.25 2 -7.731 3.2607 1.8918 -7.7468 3.0696 1.2397
3 4 -7.7468 3.0696 1.2397 -7.5041 2.675 1.775 -7.6483 3.1 2
4 4 -7.2839 2.05 1.5 -7.5041 2.675 1.775 -7.7468 3.0696 1.2397 -7.7463 2.85 0.625
3 4 -7.7463 2.85 0.625 -6.9976 1.275 1.25 -7.2839 2.05 1.5
4 4 -6.7695 0.675 1.1 -6.9976 1.275 1.25 -7.7463 2.85 0.625 -7.7267 2.5723 0
3 4 -7.7267 2.5723 0 -6.5196 0.05 1.05 -6.7695 0.675 1.1
3 4 -4.4164 -3.2996 3.4499 -4.0839 -3.6 3.325 -4.024 -2.829 4.596
4 4 -4.537 -2.825 3.6 -4.4164 -3.2996 3.4499 -4.024 -2.829 4.596 -4.6819 -2.2 3.825
4 4 -4.7446 -1.5875 4.2 -4.6819 -2.2 3.825 -4.024 -2.829 4.596 -4.7754 -1.025 4.596
4 4 0 -4.596 4.596 0 -2.488 6.005 -0.9607 -2.2 6.005 -1.768 -4.066 4.596
3 4 -1.768 -4.066 4.596 -0.9607 -2.2 6.005 -2.942 -1.53 6.005
3 4 -1.768 -4.066 4.596 -2.942 -1.53 6.005 -4.024 -2.829 4.596
4 4 -4.7754 -1.025 4.596 -4.024 -2.829 4.596 -2.942 -1.53 6.005 -4.6624 -0.6631 4.825
3 4 -2.942 -1.53 6.005 -4.5304 -0.3577 5.05 -4.6624 -0.6631 4.825
4 4 -4.2938 0.0423 5.4 -4.5304 -0.3577 5.05 -2.942 -1.53 6.005 -4.0732 0.3423 5.7
3 4 -2.942 -1.53 6.005 -3.9336 0.85 6.0051 -4.0732 0.3423 5.7
3 4 -2.31 -5.312 2.487 -4.026 -3.75 3.15 -4.2423 -3.75 2.925
4 4 -2.31 -5.312 2.487 -4.2423 -3.75 2.925 -4.6649 -3.5977 2.724 -4.746 -3.695 2.487
3 4 -4.746 -3.695 2.487 -4.6649 -3.5977 2.724 -4.9106 -3.3 2.487
3 4 0 -2.488 6.005 -1.666 0 6.5 -0.9607 -2.2 6.005
3 4 -0.9607 -2.2 6.005 -1.666 0 6.5 -2.942 -1.53 6.005
3 4 -2.942 -1.53 6.005 -1.666 0 6.5 -3.9336 0.85 6.0051
4 16 -1.9122 -2.075 -5.875 -2.7305 -1.9868 -5.7512 -2.942 -1.53 -6.005 -1.1792 -2.125 -6.005
3 16 -3.2413 -1.8894 -5.6152 -2.942 -1.53 -6.005 -2.7305 -1.9868 -5.7512
4 16 -2.942 -1.53 -6.005 -3.2413 -1.8894 -5.6152 -3.5577 -1.725 -5.4 -3.9409 -1.4832 -5.1548
3 16 -3.9409 -1.4832 -5.1548 -4.3713 -1.1831 -4.8896 -2.942 -1.53 -6.005
4 16 -2.942 -1.53 -6.005 -4.3713 -1.1831 -4.8896 -4.8795 -0.775 -4.596 -6.193 6.2931 -6.0201
4 16 -1.666 0 -6.5 -2.942 -1.53 -6.005 -6.193 6.2931 -6.0201 -4.2726 6.5444 -6.5275
3 16 -7.738 6.0876 -4.5962 -6.193 6.2931 -6.0201 -4.8795 -0.775 -4.596
3 16 -5.3443 -0.2 -4.15 -7.738 6.0876 -4.5962 -4.8795 -0.775 -4.596
3 16 -5.8589 0.4221 -3.6465 -7.738 6.0876 -4.5962 -5.3443 -0.2 -4.15
3 16 -6.2491 0.8861 -3.2607 -7.738 6.0876 -4.5962 -5.8589 0.4221 -3.6465
3 16 -6.5722 1.25 -2.925 -7.738 6.0876 -4.5962 -6.2491 0.8861 -3.2607
4 16 -7.738 6.0876 -4.5962 -6.5722 1.25 -2.925 -6.9652 1.65 -2.482 -8.7534 5.9574 -2.4785
3 16 -7.1866 2.025 -2.05 -8.7534 5.9574 -2.4785 -6.9652 1.65 -2.482
3 16 -7.4326 2.425 -1.525 -8.7534 5.9574 -2.4785 -7.1866 2.025 -2.05
4 16 -8.7534 5.9574 -2.4785 -7.4326 2.425 -1.525 -7.737 2.881 -0.772 -9.1118 5.9109 0
3 16 -8.0122 3.2603 0 -9.1118 5.9109 0 -7.737 2.881 -0.772
3 16 -8.0367 3.55 0.625 -9.1118 5.9109 0 -8.0122 3.2603 0
3 16 -8.0293 3.725 1.175 -9.1118 5.9109 0 -8.0367 3.55 0.625
4 16 -9.1118 5.9109 0 -8.0293 3.725 1.175 -8.0083 3.85 1.675 -8.7654 5.9525 2.4875
3 16 -7.9419 3.875 2.2 -8.7654 5.9525 2.4875 -8.0083 3.85 1.675
3 16 -8.7654 5.9525 2.4875 -7.9419 3.875 2.2 -7.8374 3.725 2.4874
4 16 -7.7378 6.0877 4.5962 -8.7654 5.9525 2.4875 -7.8374 3.725 2.4874 -7.6241 3.475 2.7
4 16 -7.7378 6.0877 4.5962 -7.6241 3.475 2.7 -7.4165 3.1 2.8 -5.2209 0.0446 4.5961
4 16 -6.5765 0.475 1.85 -6.2849 -0.225 1.85 -6.0307 -0.8 1.95 -6.8092 1.0804 1.9837
4 16 -5.8119 -1.25 2.15 -7.029 1.675 2.175 -6.8092 1.0804 1.9837 -6.0307 -0.8 1.95
4 16 -7.029 1.675 2.175 -5.8119 -1.25 2.15 -5.4834 -1.925 2.4871 -7.2749 2.375 2.4873
4 16 -5.1409 -2.3 2.85 -5.051 -2.3 3.025 -7.2749 2.375 2.4873 -5.4834 -1.925 2.4871
3 16 -5.1366 -1.725 3.325 -7.2749 2.375 2.4873 -5.051 -2.3 3.025
3 16 -5.2212 -0.875 3.85 -7.2749 2.375 2.4873 -5.1366 -1.725 3.325
3 16 -5.2212 -0.875 3.85 -5.2313 -0.3994 4.2159 -7.2749 2.375 2.4873
4 16 -7.2749 2.375 2.4873 -5.2313 -0.3994 4.2159 -5.2209 0.0446 4.5961 -7.3244 2.725 2.675
3 16 -7.4165 3.1 2.8 -7.3244 2.725 2.675 -5.2209 0.0446 4.5961
3 16 -5.0764 0.4 4.85 -7.7378 6.0877 4.5962 -5.2209 0.0446 4.5961
3 16 -4.8294 0.775 5.2 -7.7378 6.0877 4.5962 -5.0764 0.4 4.85
3 16 -4.8294 0.775 5.2 -4.5696 1.05 5.525 -7.7378 6.0877 4.5962
3 16 -4.248 1.2646 5.8819 -7.7378 6.0877 4.5962 -4.5696 1.05 5.525
4 16 -6.2001 6.2902 6.0053 -7.7378 6.0877 4.5962 -4.248 1.2646 5.8819 -3.9336 0.85 6.0051
4 16 -3.9336 0.85 6.0051 -1.666 0 6.5 -4.3864 6.5289 6.5 -6.2001 6.2902 6.0053
4 16 -2.942 -1.53 -6.005 -1.666 0 -6.5 -0.9783 -2.1339 -6.0199 -1.1792 -2.125 -6.005
3 16 -0.9783 -2.1339 -6.0199 -1.666 0 -6.5 -0.2299 -2.1447 -6.0733
4 82 -0.957 -2.2 -6.005 0 -2.488 -6.005 0 -2.6658 -5.8862 -1.1352 -2.6135 -5.6928
4 82 -1.9122 -2.075 -5.875 -0.957 -2.2 -6.005 -1.1352 -2.6135 -5.6928 -2.4996 -2.4856 -5.4741
3 82 -2.7305 -1.9868 -5.7512 -1.9122 -2.075 -5.875 -2.4996 -2.4856 -5.4741
4 82 -3.2413 -1.8894 -5.6152 -2.7305 -1.9868 -5.7512 -2.4996 -2.4856 -5.4741 -3.5716 -2.2859 -5.1851
4 82 -3.2413 -1.8894 -5.6152 -3.5716 -2.2859 -5.1851 -3.9591 -2.075 -4.925 -3.5577 -1.725 -5.4
4 82 -3.9409 -1.4832 -5.1548 -3.5577 -1.725 -5.4 -3.9591 -2.075 -4.925 -4.4838 -1.725 -4.596
3 82 -3.9409 -1.4832 -5.1548 -4.4838 -1.725 -4.596 -4.3713 -1.1831 -4.8896
3 82 -4.8795 -0.775 -4.596 -4.3713 -1.1831 -4.8896 -4.4838 -1.725 -4.596
4 82 -4.8795 -0.775 -4.596 -4.4838 -1.725 -4.596 -5.1768 -0.875 -3.925 -5.3443 -0.2 -4.15
4 82 -5.3443 -0.2 -4.15 -5.1768 -0.875 -3.925 -5.8897 -0.025 -3.225 -5.8589 0.4221 -3.6465
4 82 -5.8589 0.4221 -3.6465 -5.8897 -0.025 -3.225 -6.6226 0.825 -2.483 -6.2491 0.8861 -3.2607
4 82 -6.5722 1.25 -2.925 -6.2491 0.8861 -3.2607 -6.6226 0.825 -2.483 -6.9652 1.65 -2.482
4 82 -6.9652 1.65 -2.482 -6.6226 0.825 -2.483 -6.8868 1.275 -1.975 -7.1866 2.025 -2.05
4 82 -7.1866 2.025 -2.05 -6.8868 1.275 -1.975 -7.111 1.65 -1.525 -7.4326 2.425 -1.525
4 82 -7.4326 2.425 -1.525 -7.111 1.65 -1.525 -7.3608 2.05 -0.975 -7.737 2.881 -0.772
3 82 -7.5438 2.325 -0.525 -7.737 2.881 -0.772 -7.3608 2.05 -0.975
4 82 -7.737 2.881 -0.772 -7.5438 2.325 -0.525 -7.7267 2.5723 0 -8.0122 3.2603 0
4 82 -8.0122 3.2603 0 -7.7267 2.5723 0 -7.7463 2.85 0.625 -8.0367 3.55 0.625
4 82 -8.0367 3.55 0.625 -7.7463 2.85 0.625 -7.7468 3.0696 1.2397 -8.0293 3.725 1.175
4 82 -8.0083 3.85 1.675 -8.0293 3.725 1.175 -7.7468 3.0696 1.2397 -7.731 3.2607 1.8918
4 82 -7.9419 3.875 2.2 -8.0083 3.85 1.675 -7.731 3.2607 1.8918 -7.7107 3.25 2
4 82 -7.8374 3.725 2.4874 -7.9419 3.875 2.2 -7.7107 3.25 2 -7.6483 3.1 2
4 82 -7.4165 3.1 2.8 -7.6241 3.475 2.7 -7.8374 3.725 2.4874 -7.3244 2.725 2.675
3 82 -7.8374 3.725 2.4874 -7.2749 2.375 2.4873 -7.3244 2.725 2.675
4 82 -7.2749 2.375 2.4873 -7.8374 3.725 2.4874 -7.6483 3.1 2 -7.5041 2.675 1.775
4 82 -7.2749 2.375 2.4873 -7.5041 2.675 1.775 -7.2839 2.05 1.5 -7.029 1.675 2.175
4 82 -6.9976 1.275 1.25 -6.8092 1.0804 1.9837 -7.029 1.675 2.175 -7.2839 2.05 1.5
4 82 -6.8092 1.0804 1.9837 -6.9976 1.275 1.25 -6.7695 0.675 1.1 -6.5765 0.475 1.85
4 82 -6.5765 0.475 1.85 -6.7695 0.675 1.1 -6.5196 0.05 1.05 -6.2849 -0.225 1.85
4 82 -6.1724 -0.75 1.15 -6.0307 -0.8 1.95 -6.2849 -0.225 1.85 -6.5196 0.05 1.05
4 82 -5.8334 -1.475 1.4 -5.8119 -1.25 2.15 -6.0307 -0.8 1.95 -6.1724 -0.75 1.15
4 82 -5.5347 -2.075 1.725 -5.4834 -1.925 2.4871 -5.8119 -1.25 2.15 -5.8334 -1.475 1.4
4 82 -5.4834 -1.925 2.4871 -5.5347 -2.075 1.725 -5.2077 -2.725 2.1 -4.9106 -3.3 2.487
4 82 -5.4834 -1.925 2.4871 -4.9106 -3.3 2.487 -4.6649 -3.5977 2.724 -5.1409 -2.3 2.85
4 82 -5.1409 -2.3 2.85 -4.6649 -3.5977 2.724 -4.4164 -3.2996 3.4499 -4.537 -2.825 3.6
3 82 -4.537 -2.825 3.6 -5.051 -2.3 3.025 -5.1409 -2.3 2.85
4 82 -5.051 -2.3 3.025 -4.537 -2.825 3.6 -4.6819 -2.2 3.825 -5.1366 -1.725 3.325
4 82 -5.1366 -1.725 3.325 -4.6819 -2.2 3.825 -4.7446 -1.5875 4.2 -5.2212 -0.875 3.85
4 82 -5.2212 -0.875 3.85 -4.7446 -1.5875 4.2 -4.7754 -1.025 4.596 -5.2313 -0.3994 4.2159
3 82 -5.2313 -0.3994 4.2159 -4.7754 -1.025 4.596 -5.2209 0.0446 4.5961
4 82 -5.2209 0.0446 4.5961 -4.7754 -1.025 4.596 -4.6624 -0.6631 4.825 -5.0764 0.4 4.85
3 82 -5.0764 0.4 4.85 -4.6624 -0.6631 4.825 -4.5304 -0.3577 5.05
3 82 -4.5304 -0.3577 5.05 -4.2938 0.0423 5.4 -5.0764 0.4 4.85
4 82 -4.8294 0.775 5.2 -5.0764 0.4 4.85 -4.2938 0.0423 5.4 -4.0732 0.3423 5.7
4 82 -4.5696 1.05 5.525 -4.8294 0.775 5.2 -4.0732 0.3423 5.7 -3.9336 0.85 6.0051
3 82 -3.9336 0.85 6.0051 -4.248 1.2646 5.8819 -4.5696 1.05 5.525
4 82 -4.0839 -3.6 3.325 -4.4164 -3.2996 3.4499 -4.6649 -3.5977 2.724 -4.026 -3.75 3.15
3 82 -4.2423 -3.75 2.925 -4.026 -3.75 3.15 -4.6649 -3.5977 2.724
4 82 -0.2299 -2.1447 -6.0733 0 -2.488 -6.005 -0.957 -2.2 -6.005 -0.9783 -2.1339 -6.0199
3 82 -0.957 -2.2 -6.005 -1.9122 -2.075 -5.875 -1.1792 -2.125 -6.005
3 82 -0.957 -2.2 -6.005 -1.1792 -2.125 -6.005 -0.9783 -2.1339 -6.0199
5 24 -2.5 -5.75 0 0 -6.5 0 -2.31 -5.312 -2.487 -2.31 -5.312 2.487
5 24 -2.31 -5.312 -2.487 0 -6.005 -2.487 -2.5 -5.75 0 -1.768 -4.066 -4.596
5 24 -2.31 -5.312 -2.487 -1.768 -4.066 -4.596 0 -6.005 -2.487 -4.024 -2.829 -4.596
5 24 -1.768 -4.066 4.596 -2.942 -1.53 6.005 -0.957 -2.2 6.005 -4.024 -2.829 4.596
5 24 -1.768 -4.066 -4.596 0 -4.596 -4.596 -2.31 -5.312 -2.487 -0.957 -2.2 -6.005
5 24 -2.31 -5.312 2.487 0 -6.005 2.487 -2.5 -5.75 0 -1.768 -4.066 4.596
5 24 -1.768 -4.066 4.596 0 -4.596 4.596 -2.31 -5.312 2.487 -0.957 -2.2 6.005
5 24 -4.024 -2.829 -4.596 -1.768 -4.066 -4.596 -2.942 -1.53 -6.005 -2.31 -5.312 -2.487
5 24 -1.666 0 -6.5 -0.957 -2.2 -6.005 -2.942 -1.53 -6.005 0 -2.488 -6.005
5 24 -4.024 -2.829 4.596 -1.768 -4.066 4.596 -2.942 -1.53 6.005 -2.31 -5.312 2.487
5 24 -0.957 -2.2 6.005 -1.768 -4.066 4.596 0 -4.596 4.596 -2.942 -1.53 6.005
5 24 -1.768 -4.066 4.596 -2.31 -5.312 2.487 -4.024 -2.829 4.596 0 -6.005 2.487
5 24 -2.31 -5.312 2.487 -2.5 -5.75 0 -4.746 -3.695 2.487 0 -6.5 0
5 24 -1.768 -4.066 -4.596 -0.957 -2.2 -6.005 0 -2.488 -6.005 -2.942 -1.53 -6.005
5 24 -5 -4 0 -4.746 -3.695 2.487 -2.5 -5.75 0 -9.1118 5.9109 0
5 24 -4.746 -3.695 -2.487 -4.024 -2.829 -4.596 -8.7534 5.9574 -2.4785 -2.31 -5.312 -2.487
5 24 -4.024 -2.829 -4.596 -2.942 -1.53 -6.005 -1.768 -4.066 -4.596 -7.738 6.0876 -4.5962
5 24 -4.746 -3.695 2.487 -4.024 -2.829 4.596 -2.31 -5.312 2.487 -8.7654 5.9525 2.4875
5 24 -4.024 -2.829 4.596 -2.942 -1.53 6.005 -1.768 -4.066 4.596 -7.7378 6.0877 4.5962
5 24 -2.942 -1.53 6.005 -1.666 0 6.5 -0.957 -2.2 6.005 -6.2001 6.2902 6.0053
5 24 -2.942 -1.53 -6.005 -1.666 0 -6.5 -0.957 -2.2 -6.005 -6.193 6.2931 -6.0201
5 24 -5 -4 0 -4.746 -3.695 -2.487 -2.5 -5.75 0 -9.1118 5.9109 0
5 24 0 -2.488 -6.005 -0.957 -2.2 -6.005 -1.666 0 -6.5 0 -4.5962 -4.5962
5 24 -2.942 -1.53 -6.005 -0.957 -2.2 -6.005 -1.666 0 -6.5 -1.768 -4.066 -4.596
5 24 -0.957 -2.2 6.005 0 -2.488 6.005 -1.666 0 6.5 -1.768 -4.066 4.596
5 24 -2.31 -5.312 -2.487 -2.5 -5.75 0 -4.746 -3.695 -2.487 0 -6.005 -2.488
5 24 -4.746 -3.695 -2.487 -2.31 -5.312 -2.487 -2.5 -5.75 0 -4.024 -2.829 -4.596
5 24 -2.31 -5.312 2.487 -4.746 -3.695 2.487 -2.5 -5.75 0 -4.024 -2.829 4.596
5 24 -4.746 -3.695 -2.487 -2.5 -5.75 0 -2.31 -5.312 -2.487 -5 -4 0
5 24 -1.666 0 6.5 -0.957 -2.2 6.005 -2.942 -1.53 6.005 0 -2.488 6.005
5 24 -2.5 -5.75 0 -4.746 -3.695 2.487 -2.31 -5.312 2.487 -5 -4 0
5 24 -5 -4 0 -2.5 -5.75 0 -4.746 -3.695 2.487 -4.746 -3.695 -2.487
5 24 -4.024 -2.829 4.596 -2.31 -5.312 2.487 -1.768 -4.066 4.596 -4.746 -3.695 2.487
5 24 -2.31 -5.312 -2.487 -4.024 -2.829 -4.596 -4.746 -3.695 -2.487 -1.768 -4.066 -4.596
5 24 -1.768 -4.066 -4.596 -2.942 -1.53 -6.005 -0.957 -2.2 -6.005 -4.024 -2.829 -4.596
5 24 -2.942 -1.53 6.005 -0.957 -2.2 6.005 -1.666 0 6.5 -1.768 -4.066 4.596
5 24 -2.942 -1.53 -6.005 -6.193 6.2931 -6.0201 -1.666 0 -6.5 -4.024 -2.829 -4.596
5 24 -4.024 -2.829 -4.596 -7.738 6.0876 -4.5962 -2.942 -1.53 -6.005 -4.746 -3.695 -2.487
5 24 -4.746 -3.695 -2.487 -8.7534 5.9574 -2.4785 -4.024 -2.829 -4.596 -5 -4 0
5 24 -5 -4 0 -9.1118 5.9109 0 -4.746 -3.695 -2.487 -4.746 -3.695 2.487
5 24 -4.746 -3.695 2.487 -8.7654 5.9525 2.4875 -5 -4 0 -4.024 -2.829 4.596
5 24 -4.024 -2.829 4.596 -7.7378 6.0877 4.5962 -4.746 -3.695 2.487 -2.942 -1.53 6.005
5 24 -2.942 -1.53 6.005 -6.2001 6.2902 6.0053 -4.024 -2.829 4.596 -1.666 0 6.5
Official
LDraw.org Parts Tracker,
Orion Pobursky,
