Unofficial File parts/6221654pc01.dat
Part Attributes: Base Part: 6221654p.dat
Sticker  1.9 x  1.8 with Ferrari Logo and White 63 on Green Square and White Stripes on Red Background Left (Formed) Pattern
0 Sticker 1.9 x 1.8 with Ferrari Logo and White 63 on Green Square and White Stripes on Red Background Left (Formed) Pattern 0 Name: 6221654pc01.dat 0 Author: Massimo Maso [Sirio] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS 2017, 488, 63, BrickLink 75886stk01, Brickowl 731696 0 !KEYWORDS Christina Nielsen, Corsa, Ferrari, GT3, IMSA, Rebrickable 37800 0 !KEYWORDS Scuderia, Set 75886, Speed Champions
1 16 0 -15.6524 12.616 1 0 0 0 .998894 -.047023 0 .047023 .998894 s\6221654ps01.dat 1 16 0 -15.6524 12.616 1 0 0 0 .989715 -.143056 0 .143056 .989715 s\6221654ps02.dat 1 16 0 -12.8827 -1.648 1 0 0 0 .971148 -.238478 0 .238478 .971148 s\6221654ps03.dat 1 16 0 -12.8827 -1.648 1 0 0 0 .941616 -.336689 0 .336689 .941616 s\6221654ps04.dat 1 16 0 -7.5316 -14.436 1 0 0 0 .900072 -.435742 0 .435742 .900072 s\6221654ps05.dat 1 16 0 -7.5316 -14.436 1 0 0 0 .844289 -.535889 0 .535889 .844289 s\6221654ps06.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\15068b01.dat
  • decimal places exceeds the recommendation for in the library specification
None
2024-02-27 21:14:48
Orion Pobursky [OrionP]
made the following comment.
2024-02-27 21:17:59
The word "Pattern" in the description is needed to get this part past part submission. It will be removed once I correct the bug in the part check routine.
2024-02-27 21:17:59
This is obvious that it is not a pattern.
There is a problem in uploading the file that Orion is working on.
Even if you change the header after loading, you can't remove the word "Pattern" from the description
LDraw.org Parts Tracker,
