Unofficial File parts/s/6218812es01.dat
~Sticker  1.8 x  1.8 Triangular with White Logos on Black Background Right - Common Part
0 ~Sticker 1.8 x 1.8 Triangular with White Logos on Black Background Right - Common Part 0 Name: s\6218812es01.dat 0 Author: Massimo Maso [Sirio] 0 !LDRAW_ORG Unofficial_Subpart 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW
0 // Stickerback 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\stickerback018x018b.dat 0 // Primitives 1 0 -16.5 -.25 11.5503 -1.5 0 0 0 1 0 0 0 1.5 3-8chrd.dat 1 0 -16.5 -.25 -16.5 -1.5 0 0 0 1 0 0 0 -1.5 1-4chrd.dat 1 0 11.5503 -.25 -16.5 0 0 1.5 0 1 0 -1.5 0 0 3-8chrd.dat 0 // Top face 0 // Black complementary faces 4 0 -18 -.25 11.5503 -16.08925 -.25 3.845 -12.55 -.25 3.845 -15.43935 -.25 12.61095 3 0 -15.43935 -.25 12.61095 -12.55 -.25 3.845 -9.01075 -.25 3.845 3 0 -18 -.25 11.5503 -16.08925 -.25 1.28 -16.08925 -.25 3.845 3 0 -16.08925 -.25 1.28 -18 -.25 11.5503 -16.08925 -.25 .155 3 0 -16.08925 -.25 .155 -18 -.25 11.5503 -16.08925 -.25 -1.7 3 0 -16.08925 -.25 -1.7 -18 -.25 11.5503 -16.08925 -.25 -3.716 3 0 -16.08925 -.25 -3.716 -18 -.25 11.5503 -16.08925 -.25 -4.9 4 0 -18 -.25 11.5503 -18 -.25 -16.5 -16.239 -.25 -11.1 -16.08925 -.25 -4.9 3 0 -18 -.25 -16.5 -16.239 -.25 -15.1 -16.239 -.25 -11.1 4 0 -18 -.25 -16.5 -16.5 -.25 -18 -16.239 -.25 -17.1 -16.239 -.25 -15.1 4 0 -3.92925 -.25 -1.7 12.61095 -.25 -15.43935 -15.43935 -.25 12.61095 -9.01075 -.25 3.845 3 0 -3.92925 -.25 -1.7 -9.01075 -.25 3.845 -9.01075 -.25 1.28 3 0 -3.92925 -.25 -1.7 -9.01075 -.25 1.28 -9.01075 -.25 .155 4 0 -10.00925 -.25 -1.7 -9.01075 -.25 .155 -16.08925 -.25 .155 -16.08925 -.25 -1.7 3 0 -9.01075 -.25 .155 -10.00925 -.25 -1.7 -3.92925 -.25 -1.7 3 0 12.61095 -.25 -15.43935 -3.92925 -.25 -1.7 -3.92925 -.25 -3.716 4 0 7.46 -.25 -13.04 12.61095 -.25 -15.43935 -3.92925 -.25 -3.716 -1.7575 -.25 -5.806 3 0 -1.7575 -.25 -5.806 -3.92925 -.25 -3.716 -3.92925 -.25 -4.9 3 0 -3.92925 -.25 -4.9 -5.36925 -.25 -4.9 -1.7575 -.25 -5.806 3 0 -1.7575 -.25 -5.806 -5.36925 -.25 -4.9 -5.52925 -.25 -4.9 4 0 -14.48925 -.25 -4.9 -13.0425 -.25 -5.806 -1.7575 -.25 -5.806 -5.52925 -.25 -4.9 4 0 -14.48925 -.25 -4.9 -14.64925 -.25 -4.9 -13.0425 -.25 -9.395 -13.0425 -.25 -5.806 4 0 -13.0425 -.25 -9.395 -14.64925 -.25 -4.9 -16.08925 -.25 -4.9 -13.0425 -.25 -10.394 3 0 -16.08925 -.25 -4.9 -16.239 -.25 -11.1 -13.0425 -.25 -10.394 4 0 -16.239 -.25 -11.1 -8.739 -.25 -11.1 -9.62 -.25 -10.394 -13.0425 -.25 -10.394 3 0 -8.739 -.25 -11.1 -7.4 -.25 -10.394 -9.62 -.25 -10.394 3 0 -7.4 -.25 -10.394 -8.739 -.25 -11.1 -5.18 -.25 -10.394 4 0 -8.739 -.25 -11.1 -1.239 -.25 -11.1 -1.7575 -.25 -10.394 -5.18 -.25 -10.394 4 0 -1.239 -.25 -17.1 -.66 -.25 -16.952 -.66 -.25 -16.352 -1.239 -.25 -15.1 3 0 -1.239 -.25 -17.1 -.66 -.25 -17.04 -.66 -.25 -16.952 3 0 -1.239 -.25 -15.1 -.66 -.25 -16.352 -.66 -.25 -15.112 3 0 -1.239 -.25 -15.1 -.66 -.25 -15.112 -.66 -.25 -15 4 0 -1.239 -.25 -11.1 -1.239 -.25 -15.1 -.66 -.25 -15 -.66 -.25 -13.04 3 0 -1.239 -.25 -11.1 -.66 -.25 -13.04 1.3 -.25 -13.04 4 0 -1.7575 -.25 -10.394 -1.239 -.25 -11.1 1.3 -.25 -13.04 1.412 -.25 -13.04 4 0 -1.7575 -.25 -9.395 -1.7575 -.25 -10.394 1.412 -.25 -13.04 5.388 -.25 -13.04 4 0 -1.7575 -.25 -5.806 -1.7575 -.25 -9.395 5.388 -.25 -13.04 5.5 -.25 -13.04 3 0 -1.7575 -.25 -5.806 5.5 -.25 -13.04 7.46 -.25 -13.04 3 0 12.61095 -.25 -15.43935 7.46 -.25 -13.04 7.46 -.25 -15 4 0 12.61095 -.25 -15.43935 7.46 -.25 -15 7.46 -.25 -15.112 11.5503 -.25 -18 3 0 11.5503 -.25 -18 7.46 -.25 -15.112 7.46 -.25 -16.352 3 0 11.5503 -.25 -18 7.46 -.25 -16.352 7.46 -.25 -16.952 3 0 11.5503 -.25 -18 7.46 -.25 -16.952 7.46 -.25 -17.04 3 0 11.5503 -.25 -18 7.46 -.25 -17.04 6.784 -.25 -17.04 3 0 -16.5 -.25 -18 -8.739 -.25 -17.1 -16.239 -.25 -17.1 4 0 11.5503 -.25 -18 -1.239 -.25 -17.1 -8.739 -.25 -17.1 -16.5 -.25 -18 3 0 11.5503 -.25 -18 6.784 -.25 -17.04 .016 -.25 -17.04 4 0 .016 -.25 -17.04 -.66 -.25 -17.04 -1.239 -.25 -17.1 11.5503 -.25 -18
  • Decimal precision exceeds normal specification for part type
None
2024-01-22 18:01:37
posted a vote of Certify.
2025-06-17 15:15:24
edited the part header.
2025-06-20 06:27:27
Header Edits
description:
~Sticker 1.8 x 1.8 with Light Blue Triangles on Blue Background Right - Common Part
to
Rene Rechthaler [Blechtaler]
made the following comment.
2025-06-20 10:24:30
should the "Right" stay? this is the common part for both...
2025-06-20 11:03:34
I see no problem with that. This is the subfile for the right version.
2025-06-20 11:19:30
the left one also uses it (mirrored)
2025-07-29 20:17:27
2025-07-31 17:20:46
Rotated sticker back as main part.
2025-10-02 17:46:39
Fixed use of the new logo NGK.
LDraw.org Parts Tracker,
