Unofficial File parts/3626cp7p.dat
Part Attributes: Base Part: 3626c.dat
Minifig Head with Laugh Lines, White and Light Bluish Grey Bushy Eyebrows, Beard and Moustache Pattern
0 Minifig Head with Laugh Lines, White and Light Bluish Grey Bushy Eyebrows, Beard and Moustache Pattern 0 Name: 3626cp7p.dat 0 Author: Philippe Hurbain [Philo] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS BrickLink 3626pb2914, Rebrickable 3626cpr3560, Santa Claus 0 !KEYWORDS Set 10293, Set 10305, Set 10312, Set 21343, Set 21344
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3626cs02.dat 1 16 0 4 0 0 0 8 0 -6.4 0 8 0 0 t04o6250.dat 1 16 0 4 0 8 0 0 0 -6.4 0 0 0 -8 t04o6250.dat 1 16 0 4 0 0 0 13 0 13 0 13 0 0 5-16cyli.dat 1 16 0 17 0 0 0 8 0 6.4 0 8 0 0 t04o6250.dat 1 16 0 4 0 0 0 -8 0 -6.4 0 8 0 0 t04o6250.dat 1 16 0 4 0 -8 0 0 0 -6.4 0 0 0 -8 t04o6250.dat 1 16 0 4 0 0 0 -13 0 13 0 13 0 0 5-16cyli.dat 1 16 0 17 0 0 0 -8 0 6.4 0 8 0 0 t04o6250.dat 1 16 0 17 0 -8 0 0 0 6.4 0 0 0 -8 t16o6250.dat 1 16 0 17 0 8 0 0 0 6.4 0 0 0 -8 t16o6250.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3626cp7ps01.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\3626cp7ps01.dat 5 24 0 17 -13 0 4 -13 -4.98 4 -12.01 4.98 4 -12.01 5 24 0 18.5309 -12.6192 0 17 -13 4.9751 17 -12.0107 -4.9752 17 -12.0104 5 24 0 18.5309 -12.6192 0 19.8282 -11.5352 4.4144 19.8282 -10.6576 -4.4144 19.8282 -10.6576 5 24 0 19.8282 -11.5352 0 20.6954 -9.9136 3.7936 20.6954 -9.1592 -3.7936 20.6954 -9.1592 5 24 0 20.6954 -9.9136 0 21 -8 3.7936 20.6954 -9.1592 -3.7936 20.6954 -9.1592
  • Ensure correct Minifig category
  • decimal places exceeds the recommendation for in the library specification
User Vote
KnightOfTarenta Certify
2024-01-22 12:32:18
2024-03-02 08:11:04
made the following comment.
2024-03-02 08:11:44
Corrected wrong condlines color
edited the part header.
2024-08-17 17:19:43
Header Edits
description:
Minifig Head with Laugh Lines, White and Light Bluish Gray Bushy Eyebrows, Beard and Moustache Pattern
to
2025-10-17 19:23:38
Vertex issue with this condline or the sub-file (not sure):
5 24 0 17 -13 0 4 -13 -4.9752 4 -12.0104 4.9751 4 -12.0107
2025-10-18 14:03:35
What's supposed to be the problem?
posted a vote of Certify.
2025-10-18 16:35:49
I suppose it is caused by the same thing you mentioned in https://library.ldraw.org/parts/34164.
It's not causing any visible issues as far as I can tell, it's just the Unificator notions.
Given your explanation, I'll give it a go.
LDraw.org Parts Tracker,
