Unofficial File parts/6177970f.dat
Sticker  0.9 x  1.8 with Grey Piston on Green Background
0 Sticker 0.9 x 1.8 with Grey Piston on Green Background 0 Name: 6177970f.dat 0 Author: Massimo Maso [Sirio] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS BrickLink 75882stk01, Brickowl 758946, Center, Development, Ferrari 0 !KEYWORDS FXXK, Rebrickable 30899, Set 75882, Speed Champions, Tunnel, Wind
0 // Stickerback 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\stickerback009x018.dat 0 // Subparts 1 16 0 -.25 0 1 0 0 0 1 0 0 0 1 s\6177970fs01.dat 1 16 0 -.25 0 1 0 0 0 1 0 0 0 -1 s\6177970fs01.dat 0 // Complementary faces 4 15 -18 -.25 7.7731 -18 -.25 -7.7731 -16.4 -.25 -4.9 -16.4 -.25 4.9 4 0 -16.4 -.25 4.9 -16.4 -.25 -4.9 -15.55 -.25 -2.05 -15.55 -.25 2.05 3 2 -15.55 -.25 2.05 -15.55 -.25 -2.05 -13.1 -.25 0 4 0 -12.2 -.25 0 -13.0708 -.25 .4437 -13.1 -.25 0 -13.0708 -.25 -.4437 3 0 -7.2 -.25 0 -6.6 -.25 -.5 -6.6 -.25 .5 4 71 -6.6 -.25 .5 -6.6 -.25 -.5 .65 -.25 -.5 .65 -.25 .5 4 0 1.3 -.25 3.5 .65 -.25 .5 .65 -.25 -.5 1.3 -.25 -3.5 3 71 1.3 -.25 3.5 1.3 -.25 -3.5 2.05 -.25 0 3 71 6.8 -.25 3.5 4.55 -.25 0 6.8 -.25 -3.5 4 0 6.8 -.25 3.5 6.8 -.25 -3.5 7.3 -.25 -3.5 7.3 -.25 3.5 4 71 7.3 -.25 3.5 7.3 -.25 -3.5 7.95 -.25 -3.5 7.95 -.25 3.5 4 0 7.95 -.25 3.5 7.95 -.25 -3.5 8.4 -.25 -3.5 8.4 -.25 3.5 4 71 8.4 -.25 3.5 8.4 -.25 -3.5 8.95 -.25 -3.5 8.95 -.25 3.5 4 0 8.95 -.25 3.5 8.95 -.25 -3.5 9.45 -.25 -3.5 9.45 -.25 3.5 4 71 9.45 -.25 3.5 9.45 -.25 -3.5 10.25 -.25 -3.5 10.25 -.25 3.5 4 0 10.25 -.25 3.5 10.25 -.25 -3.5 11.15 -.25 -3.2668 11.15 -.25 3.2668 3 71 12.35 -.25 0 11.15 -.25 3.2668 11.15 -.25 -3.2668 3 2 13.2 -.25 0 15.55 -.25 -2.05 15.55 -.25 2.05 4 0 16.4 -.25 4.9 15.55 -.25 2.05 15.55 -.25 -2.05 16.4 -.25 -4.9 4 15 18 -.25 7.7731 16.4 -.25 4.9 16.4 -.25 -4.9 18 -.25 -7.7731
  • Decimal precision exceeds normal specification for part type
None
2023-07-24 19:58:54
posted a vote of Certify.
2023-12-18 13:20:16
edited the part header.
2023-12-18 13:20:33
Header Edits
description:
Sticker 0.9 x 1.8 with Grey Piston on Green Bakground
to
2025-05-22 21:24:26
Part Reviewer
posted a vote of Hold.
2025-07-17 19:31:57
Sry Massimo. Don‘t want to be to fussy. But the postion of some of the white vertical lines does not match well with the real sticker. For example the first one to the left. With the real sticker the white line is located in the center of the bearing or only slightly to the left.
cancelled their vote.
2025-07-17 22:18:39
2025-07-29 21:19:54
2025-10-16 22:42:25
Peter Blomberg [WUIt]
2025-11-21 14:39:59
2025-11-24 17:38:58
LDraw.org Parts Tracker,
