Unofficial File parts/u9448.dat
0 ~Magnet Cylindrical Casing for Train Base 6 x 22 Type 1
0 Name: u9448.dat
0 !HISTORY 2021-07-20 [MagFors] Original design by Niels Karsdorp
0 !HISTORY 2021-07-20 [MagFors] Added corrected, and missing edge lines
0 // holder
1 16 36 -6 0 0 -1 0 1 0 0 0 0 1 4-4ring13.dat
1 16 36 -6 0 0 -1 0 1 0 0 0 0 1 4-4ring14.dat
1 16 22 -6 0 0 -1 0 13 0 0 0 0 -13 4-4disc.dat
1 16 17 -6 0 0 1 0 15 0 0 0 0 15 4-4disc.dat
1 16 17 -6 0 0 19 0 15 0 0 0 0 15 4-4cylo.dat
1 16 22 -6 0 0 14 0 13 0 0 0 0 13 4-4cylo.dat
0 // plate
1 16 -1.5 0 0 0 0 -7.5 0 4 0 7.5 0 0 2-4cylo.dat
1 16 -1.5 0 0 0 0 -7.5 0 1 0 7.5 0 0 2-4chrd.dat
1 16 -1.5 4 0 0 0 -7.5 0 -1 0 7.5 0 0 2-4chrd.dat
2 24 17 0 -7.5 17 4 -7.5
2 24 17 0 7.5 17 4 7.5
2 24 17 0 7.5 17 0 -7.5
2 24 17 4 7.5 17 4 2
2 24 17 4 -7.5 17 4 -2
1 16 7.75 4 0 9.25 0 0 0 -4 0 0 0 7.5 box3u8p.dat
4 16 0 4 -2 17 4 -2 17 4 -7.5 -1.5 4 -7.5
4 16 17 4 2 0 4 2 -1.5 4 7.5 17 4 7.5
4 16 0 4 -2 -1.5 4 -7.5 -1.5 4 7.5 0 4 2
2 24 17 4 -2 17 8.5 -2
2 24 17 4 2 17 8.5 2
2 24 17 8.5 -2 17 8.5 2
2 24 17 4 2 0 4 2
2 24 17 4 -2 0 4 -2
2 24 0 4 -2 0 4 2
2 24 17 8.5 2 0 4 2
2 24 17 8.5 -2 0 4 -2
4 16 0 4 -2 0 4 2 17 8.5 2 17 8.5 -2
3 16 17 4 2 17 8.5 2 0 4 2
3 16 0 4 -2 17 8.5 -2 17 4 -2
0 // hook
1 16 17 -13 0 0 1 0 4.5 0 0 0 0 4.5 4-4edge.dat
1 16 17 -13 0 0 -12.5 0 4.5 0 0 0 0 4.5 4-4cyli.dat
1 16 0 -8.5 0 4.5 0 0 0 5 0 0 0 4.5 4-4cyli.dat
1 16 0 -3.5 0 -4.5 0 0 0 .5 0 0 0 4.5 4-4cylse.dat
1 16 0 -3 0 -4.5 0 0 -0.5 -1 0 0 0 -4.5 4-4disc.dat
1 16 0 -13 0 0 0 -4.5 0 -4.5 0 4.5 0 0 2-8sphe.dat
1 16 0 -13 0 0 0 4.5 0 -1 4.5 4.5 0 0 2-4edge.dat
1 16 0 -8.5 0 4.5 0 0 0 -4.5 0 0 0 4.5 1-4cyls.dat
1 16 0 -8.5 0 4.5 0 0 0 -4.5 0 0 0 -4.5 1-4cyls.dat
1 16 0 -8.5 0 0 0 -4.5 0 -4.5 0 4.5 0 0 2-4cyli.dat
1 16 4.5 -13 0 0 -4.5 0 4.5 0 0 0 0 4.5 1-4cyls.dat
1 16 4.5 -13 0 0 -4.5 0 4.5 0 0 0 0 -4.5 1-4cyls.dat
1 16 4.5 -13 0 0 -4.5 0 0 0 -4.5 -4.5 0 0 2-4cyli.dat
2 24 17 -16.97186 2 4.5 -16.97186 2
2 24 17 -16.97186 -2 4.5 -16.97186 -2
2 24 5.49785 -17.5 0 4.850836 -17.15755 1.72215
2 24 5.49785 -17.5 0 4.850836 -17.15755 -1.72215
2 24 4.850836 -17.15755 -1.72215 4.5 -16.97186 -2
2 24 4.850836 -17.15755 1.72215 4.5 -16.97186 2
2 24 17 -16.97186 2 17 -22 2
2 24 17 -16.97186 -2 17 -22 -2
2 24 14 -22 2 4.5 -16.97186 2
2 24 14 -22 -2 4.5 -16.97186 -2
1 16 15.5 -22 0 1.5 0 0 0 1 0 0 0 2 rect.dat
4 16 17 -22 2 17 -22 -2 17 -16.97186 -2 17 -16.97186 2
4 16 4.5 -16.97186 2 4.5 -16.97186 -2 14 -22 -2 14 -22 2
4 16 4.5 -16.97186 2 14 -22 2 17 -22 2 17 -16.97186 2
4 16 14 -22 -2 4.5 -16.97186 -2 17 -16.97186 -2 17 -22 -2
Needs 2 More Votes (N)
- Decimal precision exceeds normal specification for part type
None
Update ring primitives via script. This will not reset the vote status of the part.
2024-03-26 14:17:13
I think this is a duplicate of 499.dat
I think that LEGO did not have 2 separate variants of this part in the 1980's
I suggest to replace this by a MOVED-TO that file
2025-01-25 16:58:53
* Admittedly I'm not into trains so I try to figure out what we are talking about here. I try to pair them with BL:
https://library.ldraw.org/parts/27031
https://www.bricklink.com/v2/catalog/catalogitem.page?P=x547c
https://library.ldraw.org/parts/9826
https://www.bricklink.com/v2/catalog/catalogitem.page?P=x547b
https://www.bricklink.com/v2/catalog/catalogitem.page?P=x547a
Not in LDraw
My first suggestions would be adding the cylinder length to the title (X.Xmm Cylinder) and add keywords with BL ref to all magnet holders.
Not in LDraw
2025-01-25 17:09:58
i can confirm 3 variants of the closed ring variant: (i am very much into this kind of trains, i have the parts)
-short cylinder, short magnet
-short cylinder, long magnet
-long cylinder, long magnet
if the plates 2x4 with magnet holders are built into a ring with 5 studs apart, only the first short/short version doesnt connect...
the other two variants connect into a good fitting pair
pic is on DC: https://discord.com/channels/1233675339436396585/1233675825216491520/1263907428731322450
2025-01-25 18:00:26
i think i even have one of the open variants...
there are definitely open and closed variants.
2025-01-25 18:42:27
i guess we need 2 magnets for that...
D10xL6mm and D10xL7mm
the new ones should be the 10x7 like this one: 2959c01.dat
https://library.ldraw.org/parts/3370
there should be a shorter one.
guess i really need to dig the other train parts out...
then we also need two empty magnet holders (long/short), who could share the back connector (its the same)
2025-01-25 19:09:48
2 items:
- Is this variation recognized anywhere else in the community?
- Does the average user care?
2025-01-25 20:11:20
both -> no :(
but I checked the library:
70023.dat is D24xL16
u9044.dat is D26xL15
but they should be D25xL15 (D10xL6mm) and D25xL17,5 (D10x7mm)
there is a chance that both are wrong
2025-01-25 20:29:02
Make a summary, with pictures, and post it to the forums for discussion.
2025-01-25 22:12:12
https://forums.ldraw.org/thread-28633-post-56293.html#pid56293
done
do you also need sizes of the other magnets?
done
2025-06-09 08:50:05
the rear part should be subfiled, the front cup can get changed in a new variant
I also obsoleted the old magnet, should fit that one: u9044b.dat
https://library.ldraw.org/parts/46116
LDraw.org Parts Tracker,
Orion Pobursky,
Those are in the mail to Admin.
