Unofficial File parts/3005pt0.dat
View official version of part
Part Attributes: Base Part: 3005.dat
Brick  1 x  1 with Blue "0" (Numeric) Pattern
0 Brick 1 x 1 with Blue "0" (Numeric) Pattern 0 Name: 3005pt0.dat 0 Author: Tore Eriksson [Tore_Eriksson] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS Rebrickable 3005pr9992, Set 237 0 !HISTORY 2003-06-08 [jriley] BFC compliant 0 !HISTORY 2004-03-16 [westrate] added ring primitives 0 !HISTORY 2004-09-15 [PTadmin] Official Update 2004-03 0 !HISTORY 2007-05-11 [PTadmin] Header formatted for Contributor Agreement 0 !HISTORY 2008-07-01 [PTadmin] Official Update 2008-01 0 !HISTORY 2020-06-04 [Sirio] Updated the use of primitives: removed ringr.dat or ringrr.dat, removed overlapping
0 // Subparts 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3005s01.dat 0 // Primitives 1 16 0 12 -10 0 0 2.94 5.25 0 0 0 1 0 4-4disc.dat 1 1 0 12 -10 0 0 2.94 5.25 0 0 0 1 0 1-4tang.dat 1 1 0 12 -10 0 0 2.94 -5.25 0 0 0 1 0 1-4tang.dat 1 1 0 12 -10 0 0 -2.94 -5.25 0 0 0 1 0 1-4tang.dat 1 1 0 12 -10 0 0 -2.94 5.25 0 0 0 1 0 1-4tang.dat 1 1 0 12 -10 -4.8375 0 0 0 0 7.075 0 1 0 1-8chrd.dat 1 1 0 12 -10 4.8375 0 0 0 0 7.075 0 1 0 1-8chrd.dat 1 1 0 12 -10 4.8375 0 0 0 0 -7.075 0 1 0 1-8chrd.dat 1 1 0 12 -10 -4.8375 0 0 0 0 -7.075 0 1 0 1-8chrd.dat 1 1 0 12 -10 0 0 4.8375 7.075 0 0 0 1 0 1-8chrd.dat 1 1 0 12 -10 0 0 4.8375 -7.075 0 0 0 1 0 1-8chrd.dat 1 1 0 12 -10 0 0 -4.8375 -7.075 0 0 0 1 0 1-8chrd.dat 1 1 0 12 -10 0 0 -4.8375 7.075 0 0 0 1 0 1-8chrd.dat 1 16 0 12 -10 0 0 -4.8375 7.075 0 0 0 1 0 4-4ndis.dat 0 // Neutral faces 4 16 4.8375 19.075 -10 -4.8375 19.075 -10 -10 24 -10 10 24 -10 4 16 4.8375 4.925 -10 4.8375 19.075 -10 10 24 -10 10 0 -10 4 16 -4.8375 4.925 -10 4.8375 4.925 -10 10 0 -10 -10 0 -10 4 16 -4.8375 19.075 -10 -4.8375 4.925 -10 -10 0 -10 -10 24 -10 0 // Colored faces 3 1 4.8375 12 -10 2.94 10.9558 -10 2.94 12 -10 4 1 3.4206 6.9973 -10 2.7163 9.9908 -10 2.94 10.9558 -10 4.8375 12 -10 3 1 3.4206 6.9973 -10 2.4925 9.0259 -10 2.7163 9.9908 -10 3 1 2.4925 9.0259 -10 3.4206 6.9973 -10 2.0789 8.2877 -10 3 1 2.0789 8.2877 -10 3.4206 6.9973 -10 1.6655 7.5491 -10 4 1 0 4.925 -10 1.1251 7.1495 -10 1.6655 7.5491 -10 3.4206 6.9973 -10 3 1 1.1251 7.1495 -10 0 4.925 -10 .5848 6.75 -10 3 1 .5848 6.75 -10 0 4.925 -10 0 6.75 -10 3 1 0 6.75 -10 0 4.925 -10 -.5848 6.75 -10 4 1 -3.4206 6.9973 -10 -1.1251 7.1495 -10 -.5848 6.75 -10 0 4.925 -10 3 1 -1.1251 7.1495 -10 -3.4206 6.9973 -10 -1.6655 7.5491 -10 3 1 -1.6655 7.5491 -10 -3.4206 6.9973 -10 -2.0789 8.2877 -10 3 1 -2.0789 8.2877 -10 -3.4206 6.9973 -10 -2.4925 9.0259 -10 4 1 -2.4925 9.0259 -10 -3.4206 6.9973 -10 -4.8375 12 -10 -2.7163 9.9908 -10 3 1 -2.7163 9.9908 -10 -4.8375 12 -10 -2.94 10.9558 -10 3 1 -2.94 10.9558 -10 -4.8375 12 -10 -2.94 12 -10 3 1 -2.94 12 -10 -4.8375 12 -10 -2.94 13.0442 -10 4 1 -2.94 13.0442 -10 -4.8375 12 -10 -3.4206 17.0027 -10 -2.7163 14.0092 -10 3 1 -2.7163 14.0092 -10 -3.4206 17.0027 -10 -2.4925 14.9741 -10 3 1 -2.4925 14.9741 -10 -3.4206 17.0027 -10 -2.0789 15.7123 -10 3 1 -2.0789 15.7123 -10 -3.4206 17.0027 -10 -1.6655 16.451 -10 4 1 -1.6655 16.451 -10 -3.4206 17.0027 -10 0 19.075 -10 -1.1251 16.8505 -10 3 1 -1.1251 16.8505 -10 0 19.075 -10 -.5848 17.25 -10 3 1 -.5848 17.25 -10 0 19.075 -10 0 17.25 -10 3 1 0 17.25 -10 0 19.075 -10 .5848 17.25 -10 4 1 3.4206 17.0027 -10 1.1251 16.8505 -10 .5848 17.25 -10 0 19.075 -10 3 1 1.1251 16.8505 -10 3.4206 17.0027 -10 1.6655 16.451 -10 3 1 1.6655 16.451 -10 3.4206 17.0027 -10 2.0789 15.7123 -10 3 1 2.0789 15.7123 -10 3.4206 17.0027 -10 2.4925 14.9741 -10 4 1 4.8375 12 -10 2.7163 14.0092 -10 2.4925 14.9741 -10 3.4206 17.0027 -10 3 1 2.7163 14.0092 -10 4.8375 12 -10 2.94 13.0442 -10 3 1 2.94 13.0442 -10 4.8375 12 -10 2.94 12 -10
Not releaseable Errors Found (HF) Errors Found (HF)
  • Decimal precision exceeds normal specification for part type
User Vote
MagFors Hold
Massimo Maso [Sirio]
2020-06-18 04:40:02
2020-07-30 22:05:02
made the following comment.
2020-09-02 16:50:02
Looking good, but as many of the bricks in this set, the shape/font/size is wrong.
https://img.tradera.net/images/973/355816973_250d4629-5a3a-4bc8-8b66-dd796ba42e30.jpg
2020-09-04 18:30:02
There are actually 3 versions of this brick with three different fonts.
Normal: https://www.bricklink.com/v2/catalog/catalogitem.page?P=3005pt0#T=C&;C=1
Bold: https://www.bricklink.com/v2/catalog/catalogitem.page?P=3005pt0b#T=C&;C=1
Serif: https://www.bricklink.com/v2/catalog/catalogitem.page?P=3005pt0s#T=C
Soon I will send the updated version with the normal font.
2020-09-04 21:55:02
Modified version using only ellipses.
Perhaps in the vertical strokes it may be necessary to add a small straight stroke and use two half ellipses at the ends.
Existing certification-votes were deleted.
Steffen [Steffen]
2021-01-09 22:05:01
as "0" and "O" are so difficult to differentiate visually, I would like to see
"(Oh)" and
"(Zero)"
added to the titles of 3005pt0.dat and 3005pto.dat
2021-01-10 10:20:01
Fixed description.
posted a vote of Hold.
2021-01-17 15:55:02
As far as I can tell, this file is OK, but IMHO this set 3005pt0-pt9 should be obsoleted.
As it is made, it looks to be a mix of 2 fonts and sizes.
0, 1, 3, 4, 7 is correct in size, but some digits use an incorrect font.
2, 5, 6, 8, 9 belong in the set with serif font.
1 16 0 0 0 1 0 0 0 1 0 0 0 1 3005pt0.dat
1 16 20 0 0 1 0 0 0 1 0 0 0 1 3005pt1.dat
1 16 40 0 0 1 0 0 0 1 0 0 0 1 3005pt2.dat
1 16 60 0 0 1 0 0 0 1 0 0 0 1 3005pt3.dat
1 16 80 0 0 1 0 0 0 1 0 0 0 1 3005pt4.dat
1 16 100 0 0 1 0 0 0 1 0 0 0 1 3005pt5.dat
1 16 120 0 0 1 0 0 0 1 0 0 0 1 3005pt6.dat
1 16 140 0 0 1 0 0 0 1 0 0 0 1 3005pt7.dat
1 16 160 0 0 1 0 0 0 1 0 0 0 1 3005pt8.dat
1 16 180 0 0 1 0 0 0 1 0 0 0 1 3005pt9.dat
2 4 -10 5 -10 190 5 -10
2 4 -10 7 -10 190 7 -10
2 4 -10 17 -10 190 17 -10
2 4 -10 19 -10 190 19 -10
https://www.flickr.com/photos/lwr/albums/72157616995236871
https://i.ebayimg.com/images/g/ukIAAOSwS0tgBDT~/s-l1600.jpg
Or maybe we should keep the partnumbers an simply redesign the digits?
Philippe Hurbain [Philo]
2021-01-17 17:35:01
I don't think pattern correction justify obsoletization...
[PTadmin]
Part Author
edited the part header.
2021-01-23 06:50:02
Joshua Delahunty [dulcaoin]
Part Reviewer
2024-01-03 15:20:27
There must be a fourth style, as well. An initial "Normal" where the letters are much smaller and cover less of the brick surface. I recently acquired set 234 elements (by Samsonite), and the lettering is much smaller than that shown on Bricklink, or modeled in LDRAW.
Part Reviewer
2024-01-03 17:08:43
Correction:
After I made the above comment, I got into a conversation with Gary Istok about the subject.
There are 6 different typefaces on LEGO 1x1 bricks over the years, one of them quite rare from the early years just in Scandinavia.
So, there's research to be done here, and probably a numbering system should be formed.
Gary showed me images of
Continental Europe 1958 (Serifed, thick), 1966 (Serifed, thin), and 1969 (the current "bold" look, mostly if not fully done with LCAD)
USA/Canada (sans-serif, small, center of brick face) and UK/Australia (sans-serif, covers most of the face of the brick, this set is mostly done with LCAD)
and
the rare 1957–58 typeface for set 1234 in Denmark, Norway and Sweden. It looks to me a lot like the "Bold" set, but it's in the older darker blue
This part is copyright © Tore Eriksson
LDraw.org Parts Tracker, John Riley, Andy Westrate, Massimo Maso,
